Old 11-15-2010, 07:30 PM
jolee jolee is offline
Default 4:88 gears
I am thinking of installing new gears in my 97 LC. Can anyone tell me what their RPMs are at 65 to 70 mph with 315 size tires.
Thanks
Old 11-15-2010, 08:25 PM
coax's Avatar
coax coax is offline
my brain won't do math, but I think these numbers (if correct) should help figure it out for you.
The gear ratios are: 1st 2.95:1, 2nd 1.53:1, 3rd 1:1, 4th .765:1, reverse 2.678:1
The differential ratio is 4.11:1.
Circumference of 35" tire: ~110"
http://www.marks4wd.com/vehicle-info...eries-info.htm
-Corey
'74 project pig (sold)
Old 11-16-2010, 03:13 AM
Thanks
From this thread (post #63)
http://forum.ih8mud.com/80-series-te...ml#post6041809
Just putting this here for future reference since I finally found the napkins on which I wrote the info down
285s w/ Stock Gears | 285s w/ 4.88 Gears | 315s w/ 4.88 Gears (guesstimate)
60 mph = 2050 RPM ..| 60 mph = 2400 RPM .| 60 mph = 2200 RPM
65 mph = 2200 RPM ..| 65 mph = 2600 RPM .| 65 mph = 2400 RPM
70 mph = 2350 RPM ..| 70 mph = 2800 RPM .| 70 mph = 2600 RPM
75 mph = 2500 RPM ..| 75 mph = 3000 RPM .| 75 mph = 2800 RPM
Rig setup: 285/75/16 Toyo MTs with about 1/2 tread and OD on. YRMV
Based on this and Romer's numbers running 315s w/ 4.88s, bumping up to 315s will bring the RPM down about 200 or so from my numbers listed for 4.88s w/ the 285s. Added this above as a best guesstimate.
