Old 11-22-2010, 04:29 PM
CardinalFJ60's Avatar
Default running coax question
the coax for my CB antenna is nicely run through the 60. Is it OK to run the Ham Coax alongside the CB? that is, will I risk interference or anything?
Old 11-22-2010, 04:51 PM
Run it!
Old 11-22-2010, 05:00 PM
Default tonight's the night
with a little luck, I'll get a few hours in the garage tonight.
Old 11-22-2010, 05:32 PM
Very close in parallel might cause interference, but the problem will be worse on the CB than on VHF ham. Some space is better than nothing. Do what you can, the important thing is get 'er done. Good coax would help, too, which is the problem with most CB. The shield weave is crap, just crap, that they include with off the shelf stuff.
