Old 12-27-2010, 09:32 PM
I still have a twinn post lift in storage in Denver I'd like to get rid of. I would have to see what kind of condition its in as its been outdoors
anyone can PM me if your interested. Its a Challenger lift I got out of the Dodge dealer in Silverthorne. It worked for 3500 series Rams so I'm sure it will lift a Cruiser.
Old 12-28-2010, 12:55 AM
John,
Did you find something to use to lift up the car? If not, I've got some of those car ramp dealyos you could borrow. I actually use them when working on the 's low rider 80
Heck, if we could find a day/time that worked for both of us you could come by, pull in the garage and on the ramps, and we'll check it out. Pretty far south for you to come but if it works out
Old 12-29-2010, 08:00 AM
jacdaw's Avatar
jacdaw jacdaw is offline
Thanks Jeff. Daniel offered the same thing. I said we could waiy until holidaze are over.
I don't care how far I drive. As long as the loose bits don't fall off on the way. :LOL:
Jon Newquist
TLCA 19964
Old 12-29-2010, 08:37 AM
Originally Posted by 80lolux4x4 View Post
I'm not at all upset about the hijack. And that QuickLift would be a fun addition to my small garage after my transplant is done. Although the more I look at it, it doesn't seem to give much more lift than a pair of good ramp stands, especially the solid hard rubber ones. And since you drive on, wheel changes are out of the question.
It gets the bottom of the front and rear wheels a little over 20 inches off the ground IIRC, much more room under the vehicle than trying to work under a set of ramps. I've been able to drop a couple of transmissions out from under the 40 and the vette with it. Overall its a good height for doing a lot of work.
I've had both vehicles stored long term on the QuickLift and done lots of projects that included axle work. Getting the axles supported is a PITA with the Qwicklift since they end up way too high for a jack stand without rigging some kind of stable platform for the jack stands to sit on. I home brew so I use empty kegs which work out to be a good height. Commercial truck type jack stands would be another option, but they are heavy and pretty large to store.
Old 01-03-2011, 06:35 PM
jacdaw's Avatar
I was tightening my lugs nuts today (30 days of 4 miles/day on new wheels/tires) and stumbled upon what's loose. The front lower rubber shock bushes are ruined and the shocks are rattling in the lower mounts. I can't tell if the shocks leaked or something else got on the bushes. So no lift needed, I just need to get some urethane bushes or worst case, new shocks.
Thanks for the offers to get my car off the ground!
Jon Newquist
TLCA 19964
