Old 12-29-2010, 12:30 PM
Default FJ60 5.3 Vortec Failed Emissions
Holy cow, I didn't expect to see this when I went to get my emissions done!!!
Two years ago I barely squeaked by. This year I failed miserably.
I need to start looking at timing maybe? Maybe that speed sensor that has never worked right is messing things up?
Old 12-29-2010, 12:38 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Well it is a chevy
TLCA # 20314
Step by Step Bed Bob
Old 12-29-2010, 01:08 PM
Chris's Avatar
Chris Chris is offline
And the standards have been tightened. Good luck Marco, I had a stock Yota 3FE that I eventually got to pass after 7 attempts. Thst's a big part of why the 62 is now owned by a guy in Iowa and I'm drving a 4Runner now.
Old 12-29-2010, 01:39 PM
Its odd that the CO and CO2 readings are high at the same time. It must be running really rich. Is the O2 sensor healthy?
Old 12-29-2010, 01:47 PM
I am assuming that the sensors are healthy... I mean, they are switching nicely in the software, fuel trims are what they should be, and timing is what it should be even.
They are probably 4 years old now?
Funny thing is it runs great.. no smoke, no nothing. gets decent mileage (14-17 depending), doesn't knock or ping either.
I need to dig into it tonight.
Old 12-29-2010, 01:54 PM
yikes, good luck Marco.
Old 12-29-2010, 01:55 PM
Are you sure it's going into closed loop?
Old 12-29-2010, 01:56 PM
satchel's Avatar
satchel satchel is offline
What!? That sucks! Has it always been close to failing? When I had mine done in May it passed with flying colors, my speed sensor doesn't work correctly either. I hope the 5.3 in mine doesn't do the same after a couple of years. I have my dad's tahoe with the 5.3 at the moment and if you would like I can bring it out and we can hook up your laptop and compare numbers from mine to yours. Then again, it is a Texas truck that has never had to deal with emissions so for all I know it would fail too so it may not be the best to compare numbers to.
Old 12-29-2010, 02:02 PM
Now that's an interesting thought.... last time I checked it was. that was only a few months ago. I need to hook it up to the computer and see.
Originally Posted by satchel View Post
What!? That sucks! Has it always been close to failing? When I had mine done in May it passed with flying colors. I hope the 5.3 in mine doesn't do the same after a couple of years. I have my dad's tahoe with the 5.3 at the moment and if you would like I can bring it out and we can hook up your laptop and compare numbers from mine to yours. Then again, it is a Texas truck that has never had to deal with emissions so for all I know it would fail too so it may not be the best to compare numbers to.
Mine was close the last time, but it passed. nowhere near this bad though. I kinda doubt that if you have yours running right now anything will change.
Funny thing is it almost passed the requirements for an 85' truck... just fails for later model requirements. I need to get it figured out though... it should be running perfectly.
Old 12-29-2010, 02:30 PM
satchel's Avatar
Well, it sounds like you are running rich, and I find it interesting that the MAF sensor you have on your truck currently was causing my truck to run rich. Maybe we should swap again and see how it does.
