Old 12-29-2010, 01:42 PM
Originally Posted by satchel View Post
Well, it sounds like you are running rich, and I find it interesting that the MAF sensor you have on your truck currently was causing my truck to run rich. Maybe we should swap again and see how it does.
Just did a TON of reading on HP Tuners' site... I am going to try to "tune" the MAF sensor tonight....
Old 12-29-2010, 01:52 PM
satchel's Avatar
satchel satchel is offline
Well if you want me to bring the Tahoe out, just let me know. We can swap sensors around and such to troubleshoot if you like.
Old 12-29-2010, 03:58 PM
Are your numbers similar to 2 years ago, but you failed because of the new standards? Or have your stats degraded?
Old 12-29-2010, 05:32 PM
everything was Juuuuust under the limit last year... like .1 under the limit. I got lucky. This year they are like double the standard. this is based on the same standards that have not changed for me anyways.
I just got done tuning the MAF sensor and it runs about the same. It was max maybe 4% off anywhere but i figured tweaking it wouldn't hurt.
I did notice that the vss was not working at all... no speed input into the computer. I'll be digging into that tonight
As far as closed loop goes I confirmed that it was indeed running in closed loop. Above a coolant temp of 131F anyways. Thats the stock number for it.
Old 12-29-2010, 06:29 PM
Chris's Avatar
Chris Chris is offline
Compare the previous test limits, they're lower than this year. I'm curious how much they changed.
Old 12-29-2010, 06:45 PM
mine are the same.
dunno why but they are. and the previous test was 2 years ago (meant to say 2 years ago in the previous post). Keep in mind that my truck has a swap so it follows a weird set of rules.
Old 12-29-2010, 07:03 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Marco,
My 350 is out of a 92, but they base the pass/fail back to 1970 requirements. I passed the last two years no problemo, but I went to collector plates this time so I can beltch pollutants for ever and evah. You might want to swap out the O2 sensor(s) and give it another go.
What a pain.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 12-29-2010, 07:24 PM
Yeah, I actually noticed on the test sheet a few hours ago that it said to test it as an "85 light duty truck" and they tested it as a newer car hence the tight limits. I was going to bring it up when i went back, but I still fail the standards for an 85 truck so I'm not going to get through as is. My goal is to get it to where it is supposed to be since it being off probably means something is not right.. it *should* run with very low emissions.
I pulled the VSS out of it and broke it in the process... so NAPA is going to have to order one. Says it'll be here at 10 tomorrow. Maybe that will help.
After that I am going to look at other stuff like o2's and cats. It was running lean for a long time so maybe that did something to the cats..
Old 12-29-2010, 08:12 PM
bh4rnnr's Avatar
bh4rnnr bh4rnnr is offline
Knowing that I failed a few years back, before running it on the highway to get things warmed up, did you run it on the highway before hand? Get that baby warmed up! Makes an amazing difference!!
4th gen Coloradoan.
Old 12-29-2010, 08:15 PM
oh yeah, she was hot.
