Old 01-03-2011, 04:56 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default Wheel flare
The flare on my wheel has been rattling around (due to rusting of clips) so I removed it today. Now I have this unsightly bracket look going on. I'm curious to know what most 80 owners do here? Do you simply replace it with OEM parts? Or have it removed (on all 4?) all together, or go with a non OEM flare?
Thanks
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 01-03-2011, 05:28 PM
Depends on what look you like?
If you like the look with the flares (which I do) then fix it and put it back on...I haven't had the priviledged yet of fixing a flare to know what you need to get/do but others have and will hopefully chime in...
I like Uncle Ben's thoughts on the flares that he told me once which in summary was something along the lines of they are useful for letting you know you are getting close to causing real and costly damage to the body...Sort of a buffer zone
If you like the look of a flareless 80, remove all the flares, cover up the holes, and paint or line the affected areas.
Old 01-03-2011, 05:43 PM
LETSROLL's Avatar
Good input. Does anyone have some pics of a flare-less 80 they can post up? I'd like to see what it looks like.
Thanks!
LETSROLL
TLCA#19430
Old 01-03-2011, 06:32 PM
Convert's Avatar
Convert Convert is offline
Thanks!
Flareless
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 01-04-2011, 07:31 PM
ajax ajax is offline
i drilled out that bracket took 2 secs get a drill bit the size of the rivet head and drill it then plug your holes with somethin
Old 01-04-2011, 09:41 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
plug it with another rivit.... clean and modern looking.
TLCA # 20314
Step by Step Bed Bob
Old 01-05-2011, 10:21 AM
LETSROLL's Avatar
Originally Posted by Convert View Post
Flareless
Awesome pictures. Thanks. Geez though. Now if I do it, my truck will look like yours! You OK with that?
LETSROLL
TLCA#19430
Old 01-09-2011, 07:37 PM
L43dean L43dean is offline
Default flare-less?
Yep, sure enough it starts with the NA spec. flares. "I done got rid of those runnin boards already". Then those wide alloy wheels, what oem steel rim fits? Maybe some good ole bias ply Interco's, yeah I know the auto trans but I can get the hand crank window regulator from an old UN 80 in Pakistan. All this carpet? Look, a steel floor and drain plugs. I want a diesel. Hey did you see that old Hi-Lux with the Russian AA in the box on BBC? Hooks on the outside bedrails and a two handle tailgate! Man I've got to convert to part time 4wd, manual hubs or drive plates? No more latte's for me, I'm brewin AKBAR Bergamont on my Optimus 00 kerosene stove from here on out. Where do I mount the sand ladders? No I don't have ADD.
Old 01-09-2011, 10:04 PM
Crash's Avatar
Crash Crash is offline
AADD, perhaps, Deano? You guys with factory spring-overs have such an attitude.
Old 01-10-2011, 01:07 AM
Default Aadd?
ADD-Automatic Differential Disconect. Sincerely, Dan's 80 and Bill's 60 both look good w/o flares. Factory spring over helps with altitude, I don't know what to do about attitude, maybe the authority guys can help.
