Notices
Old 01-20-2011, 06:18 PM
Phrog Phrog is offline
Default Weld removal?
I want to take the bent step and bumperette off the bumper of my 40.
However they are welded on. Can I break/cut a weld with a hacksaw,
chisel, or butane torch; or do I need to take it to a welding shop?
Thanks.
-Phrog
Old 01-20-2011, 06:35 PM
grinder with a cut off wheel probably work the best. Hack saw might take while
Old 01-20-2011, 07:18 PM
RockRunner's Avatar
X2 grinder is the best unless you can not get into the area. You can also drill it out if you have really good drill bits. Plasma cutter works too if you have one. There are people that can help you in the club including me depending on where you live.
A picture speaks a 1000 words, I can't remember how those are bend and attached etc.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 01-20-2011, 08:01 PM
Thanks. I'll post a pic - may take a few days.
-Phrog
Old 01-20-2011, 09:03 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
any of your above listed methods are good at cutting steal. the ginder is going to the cleanest unless uhave a plasma cutter
TLCA # 20314
Step by Step Bed Bob
Old 01-21-2011, 09:22 AM
I use the thin 4.5" slicing disks for things like this - cut most of the way through the weld, then bend the part, and snap the weld. Try not to cut all the way through the weld because you'll hack the metal underneath.
Then switch to a grinding disk and grind off the remaining weld bits carefully, to avoid hacking the 'cruiser behind the weld.
Old 01-21-2011, 09:31 AM
X2!
Colorado Trail Patrol
Stay on the Trail!
Old 01-22-2011, 04:25 PM
Buy a 4.5" grinder not 4"
Old 01-22-2011, 04:56 PM
Default re weld removal
Pics attached - one of the bent step and bumperette,
and one (blurry) of the weld itself.
Sounds like I have an excuse to buy a grinder!
-Phrog
Old 01-22-2011, 05:03 PM
That reminds me of some plates that were welded on to my front frame. I used a grinder to get them off and build my front bumper out of c-channel. The work took much more time than I thought it would, but persistence paid off and the results were just fine.
