Old 06-02-2010, 12:17 AM
Myredyota's Avatar
Myredyota Myredyota is offline
Angry Idler Arm Help!!!
My truck likes to eat idler arms. It has 33X12.5 Muds so it gets plenty of traction. Locking it into 4 wheel drive while in the snow on the road, does no harm. Lock it in to wheel, or like this weekend, to pull a fence post, the freakin' thing is toast! I am so tired of this. I know Downey made a reinforcement for this, but they are gone. Now what? I am not ready for a SAS. I have no welder, or the time to do a SAS on my own. The truck is pretty much a daily driver so I really like the ride of the IFS.
Carey--Arvada
2017 Tacoma SR5 (mall crawler)
Old 06-02-2010, 07:03 AM
A couple of options.
I think Northwest Offroad still sells an idler arm brace.
http://northwestoffroad.com/
You can replace the nylon bushings with bronze.
http://www.custommachiningusa.com/Specialty_Items.html
http://www.yotatech.com/f116/solid-b...ng-kit-114974/
Another is to use a Total Chaos arm.
http://www.chaosfab.com/toyaccess_4wd.html
I have the TC arm, which wasn't cheap back in 2005 or whenever I bought it. But it's gone 5 years without deflecting. It will no longer be your weak link.
Old 06-02-2010, 09:32 AM
Myredyota's Avatar
Thanks Dave,
I found that thread last night on YotaTech. I also found that Frank, the guy that makes the ball joint spacer, makes some bushings also. His are for an aftermarket arm, but he lists the part # and everything. Same price. I may give NORWEST a call today.
Carey--Arvada
Old 06-02-2010, 10:04 AM
Originally Posted by Myredyota View Post
Thanks Dave,
I have Frank's (SDORI) ball joint spacers, he does good work. If he is making them they will be a good product. You might also check with Roger Brown (4Crawler) since he makes and sells lots of things for mini trucks he might have a source for replacement idler arm bushings.
Old 06-02-2010, 03:44 PM
Cheese Cheese is offline
Send a message via AIM to Cheese
I used the NAPA lifetime warranty in 5 states and a total of 7 stores replacing more than one a month. In terms of traction, BJ spacers, a pair of lockers, a 3.4 and a crawler also helped.
I tried the Downey brace and bent it on the first trip.
The only thing that I have seen that was worth a darn for keeping idler arms alive with the crappy steering was the Total Chaos arm.
Get rid of BJ spacers, relax the torsion bars and buy a Total Chaos arm.
Adrian Flygt
Sold 4Runner, thanks meth heads.
"There's a feeling I get when I look to the west and my spirit is longing for leaving..."
www.sleeoffroad.com
www.sonoransteel.com
Old 06-02-2010, 04:00 PM
Mr Bill can fix all your issues with a plasma cutter
Old 06-02-2010, 04:24 PM
The bronze bushings are the cheap and simple solution. Unless you're offering a SAS for $50, in which case I'm second in line.
Old 06-02-2010, 09:53 PM
Until you bend a tie rod or rip a connector sleeve.
No one wants to talk about this because the bandaids are interesting, but there is a solution to this.
Adrian Flygt
www.sleeoffroad.com
Old 06-03-2010, 12:46 AM
Myredyota's Avatar
Cool
Dave, I think Roger is selling the bushings that Frank makes. I called Northwest this morning and ordered the brace, it should be here next week.
Bill, you crack me up! You have been egging me on about an SAS since we met! You and my neighbor would make a great team. He wants to put a couple of Danas under my baby and keep it low but stuff 40's under it too!
Say Cheese! You are right, you put a bandaid on one thing and it will reveal the next weak link.
Carey--Arvada
Old 06-03-2010, 12:06 PM
Default I added a grease nipple
I drilled my idler arm body and put a grease nipple in between the bushings. I bought undersize bushings and drilled then out so they were still a little too small too.
I also had the downy idler arm brace and never bent the arm.
Then I chopped it all off and went SAS.
KD0FDS
Stephen
