Old 01-25-2011, 09:16 AM
DenCo40 DenCo40 is offline
Default FJ40 Intake manifold
I am making a fluid heat riser for my 40 and wonder if anyone in Denver that might have their intake manifold off or one just laying around. I need to trace the bottom so I can fab up my riser plate. Mine has too much stuff in the way...
Thanks
2007 LX470
KD0WJN
Old 01-25-2011, 09:59 AM
I recently went through this and found there are two styles of intake manifold bottoms. If you have the 2F type bottom, pm Corsair23 to see if he still has a fluid heat riser kit that you might be able to use for the template. If you have the 1F bottom, I have an intake manifold that you can use to do the template - that said the bottom of the 1F intake manifold does not have a "big cavity" that would work very well with a flat plate.
I have the 1F style and did not feel comfortable with a flat plate, so I ended up searching through old Classifieds on MUD and found a fluid heat riser that never sold, the guy still had it and was happy to sell it to me.
I ran without a the fluid heat riser for a few weeks and got it installed just before this last snap of single digit temperatures. It makes a huge difference.
Without the fluid heat riser on a cold start in low temperatures, it took a long time (10-15 minutes) of fully choked running before the engine would operate well - with the fluid heat riser, after a minute the manifold is warm enough that acceleration is smooth and the choke can be backed off. If you are running a header, I highly recommend installing a fluid heat riser.
Old 01-26-2011, 03:30 PM
2F is what I am looking for. I know its the way to go for sure. The cold weather start ups are absolutely ridiculous on mine. It's even cold blooded on cool summer mornings.
2007 LX470
KD0WJN
Old 01-26-2011, 03:34 PM
I'm running a header on my 2F with no heat riser and never thought it was bad. Pull the choke, pump the pedal a few times and crank it over. Sometimes it takes a couple of tries, but it always starts and I usually can push the choke back to 1/2 almost right away. Choke all open within a few minutes of driving.
Does the heat riser really make that much difference??
Old 01-27-2011, 12:13 AM
nattybumppo's Avatar
I have a spare manifold from a 75 2f you can borrow for your fab project if you want it. I just need to take it off the engine it is on.
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 01-27-2011, 09:18 PM
No need to go thru any trouble. I was just hoping someone in the area would have one laying around.
2007 LX470
KD0WJN
