Old 02-10-2011, 02:51 PM
Ricardo, I think technically that should be DD38/38, so you can designate both throttle plate sizes. But that is neither here nor there...
Yeah, I could have it wrong from the technical name.
Sean, it would probably be worth checking your idle solenoid. The only serviceable part is the o-ring that goes on it. It may have disintegrated and possibly got pieces lodged in the idle circuit somewhere.
If Sean's carb is the DD38/38 the idle cutoff solenoid does not have an o-ring. The o-ring came into play on later carbs.
Old 02-10-2011, 05:05 PM
well, that goes to show you that two heads are better than one!
Old 02-10-2011, 05:15 PM
^Which one of you is Homer?
  #24
Old 02-10-2011, 05:25 PM
Which one is Gomer?
  #25
Old 02-10-2011, 06:50 PM
Ricardo always seem to be smiling so that must make Radar, Homer right?
  #26
Old 02-10-2011, 08:18 PM
I've got two alter egos
