Old 02-13-2011, 08:14 PM
DenCo40 DenCo40 is offline
Default 2f timing
I would like to know what timing degree people use on their 2f for high altitude (above 5280 elev.) I know some people have luck advancing it a little helps...
2007 LX470
KD0WJN
Old 02-13-2011, 10:23 PM
I think stock is 7 degrees, some people run up around 11 degrees or so. I've had people tell me to advance it until it pings/knocks at load and then back off a couple degrees. I'm a couple degrees more advanced, not exactly sure how much.
Old 02-14-2011, 07:50 AM
One rule of thumb is to have the steel ball just at the edge of the sight window - which is about 4 degrees advanced, as Matt said. If you have pinging or hard starting, you're too far advanced. You won't get a huge performance boost, but every bit counts.
Old 02-14-2011, 07:51 AM
ttubb's Avatar
ttubb ttubb is offline
Default Crested Butte Timing
I am in Crested Butte (10,000) and I have been running about 13 degrees for the last two years. Works great and this is on a freshly overhauled engine with a shaved head (higher compression).
I just adjusted the distributor to the best/smoothest running point. T
KA7TLT - TLCA 13015
Old 02-14-2011, 03:57 PM
I'll give that a shot. I have been running it stock but heard something a while back about advancing the timing a bit seems to run better at altittude.
Thanks
2007 LX470
KD0WJN
Old 02-14-2011, 04:30 PM
CBone's Avatar
CBone CBone is offline
Send a message via Yahoo to CBone
I'm running at 11
2013 4 Door Tacoma (locked, lifted and loaded with essential accoutrements for adventure)
FWC on it's back as often as possible
TLCA#11073
Old 02-14-2011, 04:36 PM
Disappointing
Originally Posted by CBone View Post
I'm running at 11
"These go to eleven."
Originally Posted by nakman
Old 02-15-2011, 02:28 PM
Stock is 7 BTDC, which corresponds to the BB on the flywheel. I run anywhere between 9-15 depending on which Cruiser and what the setup is and how worn out the motor is. Lower compression = more advance needed. It also depends a lot on how much centrifugal advance the distributor has, and it depends on whether you have vacuum advance, vacuum retard, both, dual advance, etc. I'd start at 11 and then play around with it, that's what I normally do on my own rigs. If you have points, don't forget to set them first! Correct gap is 0.018" or just about the thickness of a matchbook cover.
Old 02-15-2011, 10:29 PM
I use this approach too. I set it, then run it up a hill under full power and see how it acts. I am at the edge of the window.
Thats why I switched out to a fj60 electronic ignition... no mo' points!
Old 02-16-2011, 01:45 PM
Edge of the window = 2 from the center, so you're at 9. I use a dialback light, which is how I know where the edge of the window is!
