Notices
Old 02-22-2011, 06:56 PM
Eldorado556's Avatar
Eldorado556 Eldorado556 is offline
Default Hood insulation replacement
One of the things I did this weekend was replace my old nasty hood insulation. I was greasy, dirty and I suspect mice had been living in it.
Kinda nasty underneath.
Realized all the globs of adhesive or whatever holding the hood down have come off. I'll need to address that later.
Cleaned it up a bit
Had to pick up some new clips. Most of the old ones broken when I removed them.
Just needs trimming.
1984 FJ60 "Bjorn"
Old 02-23-2011, 08:33 AM
looks good, I need to do something similar to mine....
Old 02-23-2011, 11:49 AM
Much better
Old 02-23-2011, 11:56 AM
what kind of matting is that?
Old 02-23-2011, 02:09 PM
Looks like the Reflictix stuff, also used under the mattress in popups.. http://www.popupexplorer.com/forum/i...?topic=74525.0
Old 02-23-2011, 03:46 PM
Yup. Good old Reflectix.
I'll be putting some inside my doors this weekend.
1984 FJ60 "Bjorn"
Old 02-27-2011, 07:41 AM
Tossed some Reflectix in my rear doors yesterday. The second door went a bit smoother than the first. I cut the first a bit short where the bottom curves. I made the second piece longer and was able to tuck it in nice and snug.
I got to thinking about what to use as a replacement for the plastic dust seal you have to take off. I thought Tyvek would work great. Into The Wind, the kite shop in Boulder, sells 60" wide pieces for $3.50 a yard. 2 Yards should do all 4 doors. Much cheaper than buying a roll of house wrap. You could go really cheap and just tape together some large priority mailing envelopes.
1984 FJ60 "Bjorn"
