Old 03-06-2011, 10:58 AM
PhatFJ PhatFJ is offline
Default Rear Axle seal SW area
I ordered rear axle seals from Stevenson and only one came in. I pulled the axles this weekend and was wondering if someone has a spare available, I will replace it with the toyota one which should be tomorrow they said. If you are in the SW area that would be even better. by the way this is a 1970 semi float.. FJ40.. toyota part #- 90311-47029
Thanks, Brian
KD0GEG
Old 03-06-2011, 12:49 PM
RockRunner's Avatar
I have a bunch of seals from a front mini axle, would those fit? LMK
Thanks T aka Tom KR0MPS
TLCA #6136
Old 03-06-2011, 01:10 PM
I think I have some. I'll go check.
But, I am far far away from you.. and They may be from Napa anyways..
Old 03-06-2011, 01:54 PM
Default Thanks
Hey guys, THANKS a-lot for looking into this!! I thought I had a chance of getting this done this afternoon but it does not look like I will, so I will just wait till the Toyota seal comes in tomorrow... Thanks again I really appreciate the thought!!!
KD0GEG
Old 03-06-2011, 02:43 PM
Had some from NAPA. Sounds like you've got a new plan tho.
Old 03-06-2011, 04:10 PM
RockRunner's Avatar
Good luck!
TLCA #6136
Old 03-07-2011, 08:36 PM
Just wanted to follow up. Got the seal today and all went well with the install, I am now moving forward on the rear disc conversion.. By the way I called Carquest to check on a seal and they wanted $22.00 for one. Toyota retail is $13.?? and with the RS discount it's $8.83, as a matter of fact both the Transfer case input and output seals were the same price.. WOW way to go Toyota!!
Thanks Stevenson..
KD0GEG
