Old 03-10-2011, 08:10 PM
Skip Skip is offline
update on my heater
removed blower vent box in the cab
alot of stuff on top of core blew it out and vacumed cleaned defrost hoses pretty clean before I started. Although not hooked up very well, reatached and taped in place.
Found a small door and a connectiong rod (I assume) laying down on top of core (Explains not being able to shut down that vent. I pushed it in place and taped closed for now till I can get the unit on the bench and rebuild gasket.
Reatched inside blower vent Camper tape again works pretty well at both ends
I now have defrost and better heat flow i even had to turn it off for a while while out this am thats a first for this trusty rusty
Thanks for all your help
I came across a third smaller hose behind the two attached to the core.
it is not attached to anything in the cab. ANy idea what it might have been or should b 4
I already have two hoses comming thru fire wall for rear heater
