Old 03-07-2011, 08:30 PM
PhatFJ PhatFJ is offline
You can use a bolt/stud extractor if there is enough sticking out, if not, drill and remove with a screw extractor. There is a double seal mod you can do on the speedo gear case if you want, here is the link http://forum.ih8mud.com/40-55-series...iteup-how.html
I just did it this weekend and it went really well!! SOR does sell the parts you need but you may be just as well off getting them from Toyota.. Good luck!!
KD0GEG
Old 03-07-2011, 11:19 PM
So, if the heads snapped off; you should be able to remove the speedometer housing and have a large amount of the bolt that you can put the "metric #12 vice grip socket" onto and remove the remains.
They probably sheared so they will most likely be flush with the housing.
Old 03-08-2011, 09:51 AM
Red72FJ40 Red72FJ40 is offline
Thanks, Phat, I'll look into it.
Kevin, yep they sheared off, and that backing plate must have been rubbing against there as it spun so the are now "ground" flat!
