Old 03-14-2011, 05:31 AM
BournID's Avatar
BournID BournID is offline
Default ABS light ON after elocker axle swap?
Absent taking the light out for smog inspection, any ideas on what is causing ABS light to be on ever since I did a elocker swap going from 4.10 to 4.30 at the time. (99 4Runner)
Honestly, the brakes never did pulsate, there isn't one option on the vehicle ( 2.7, 5sp, power nothing, no roof rack, old style metal wheels, so unless ABS was standard. I'd question there existence, but there is a light on and there were magnetic sensors in the rear hubs.
Chevy forums mention a ecu reprogramming of ABS for re-gearing, but can't find anything on Toyotas.
Seems like I'm taking alot, but I will give when I can....
Tom
Old 03-14-2011, 10:45 AM
Sounds like you removed the sensors when you did the swap? That would do it!
KDěRCH
Old 03-14-2011, 10:48 AM
Does the 3rd gen 4Runner have a ABS indicator diagnostic like Land Cruisers? If you've got a port on the truck that you can apply a jumper and get some trouble codes, that might help you pinpoint the issue. If you have an FSM, it would be detailed in there.
Old 03-14-2011, 11:28 AM
BournID's Avatar
Oops.. I gues I should have used the ones in the axle and not the ones on the old axle plugged into the truck.... Live and learn... Ruined forever?
A novice wrench turner...
