Old 03-24-2011, 01:55 PM
RockRunner's Avatar
Question can I install an ARB locker in an E locker high pinion?
So my motor on my front locker has given up It is hard to only find a motor so I would have to buy the entire locker assembly and that is expensive.
So the question is can I install an ARB in my E locker High pinion third?
Thanks T aka Tom KR0MPS
TLCA #6136
Old 03-24-2011, 02:14 PM
waggoner5's Avatar
Most of the time, you can take the motor apart, clean everything and reassemble. You do have to mark the clocking of the gears so you get it back together right.
Old 03-24-2011, 08:29 PM
RockRunner's Avatar
I am going to try that, I did that once before and made my own contacts. May try that Saturday night, don't I live an exciting life
TLCA #6136
Old 03-27-2011, 10:25 PM
slowtoyota slowtoyota is offline
I have an open high pinion third you could definately put a ARB in that I would trade and add in some $.
Old 03-27-2011, 10:33 PM
RockRunner's Avatar
Sounds interesting. I will try to rebuild the motor first and go from there.
TLCA #6136
Old 03-28-2011, 12:07 AM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
not unless the arb, comes with that large 4-5" bearing on the lock side, that the e-locker has.. or have somthing machined up to adapt a smaller bearing into a elocker bearing location.
TLCA # 20314
Step by Step Bed Bob
