Old 03-26-2011, 10:56 AM
Eldorado556's Avatar
Eldorado556 Eldorado556 is offline
Default Replacing starter...does this look extra dirty?
Just took out my starter. Inside the bellhousing it seems a bit nasty. Was just wondering what level of funk I should expect inside. I know my clutch fork boot isn't on properly, so possibly dirt could be getting inside?
1984 FJ60 "Bjorn"
Old 03-26-2011, 08:43 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
looks ok, it does apear the that your rear main seal is leaking.. but i have seen much much worse.
TLCA # 20314
Step by Step Bed Bob
Old 03-26-2011, 08:57 PM
Yeah man, it doesn't look too bad. Stick in the new starter and don't look back. When it starts leaving a big spot at work then worry about it.
