Old 03-29-2011, 01:11 PM
Dr. Schlegs's Avatar
If I remember correctly from my last visit to Randy's to help him bleed his brakes, they are Nitro 4.88's. Not that they are mine I just saw them glistening in the warm glow of fluorescent lighting.
TLCA#5366
Old 03-29-2011, 01:32 PM
Originally Posted by powderpig View Post
If it is the rear differential, the rear pinion shim is usually around .050(old ones that I remove are typically this thick) when i remove to install lower gear ratio gear sets. As for the bearing caps, good luck on that one fit hey are not marked. One way to make sure is to loosely install the bearing caps and see if the threads will line up easily, and the adjusting nuts will work easily.
As for putting 150 lbs of torque on the bearing with out the crush sleeve, I would bet that the bearings are going to reach a preload with a lot less force.
What gear ratio is one using? What brand of gears are you using. I did not read the orginal post that well and commented on something that does not pertain.
More information is better than not enough.
If it is the rear differential, the rear pinion shim is usually around .050(old ones that I remove are typically this thick) when i remove to install lower gear ratio gear sets. WHAT IF IT IS A FRONT DIFF? ANY GUESS ON SHIM SIZE?
As for the bearing caps, good luck on that one fit hey are not marked. One way to make sure is to loosely install the bearing caps and see if the threads will line up easily, and the adjusting nuts will work easily. AGREED
As for putting 150 lbs of torque on the bearing with out the crush sleeve, I would bet that the bearings are going to reach a preload with a lot less force. AGREED
What gear ratio is one using? What brand of gears are you using. 4.88 NITROS
[/quote]
Old 03-29-2011, 01:35 PM
To be clear, said individual just showed up (probably to mooch something from me) and I happened to put him to work pumping the pedal (which he is qualified to do) instead of hooking up the power bleeder.
Old 03-29-2011, 01:50 PM
When was Tom over to your place?
TLCA#5366
Old 03-29-2011, 02:07 PM
Hey, I left out the part about it taking me longer to explain the pump-hold-release-pump cycle to you than it would have taken to hookup the power bleeder Leave poor old Tom out of this
Old 03-29-2011, 02:25 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Hey, Leave poor old Tom out of this
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 03-29-2011, 03:59 PM
powderpig's Avatar
Stock pinion shim for the front is close to .070.
This only works if you have the same koyo bearing that came out of the diff from the factory.
As for the kits that JT sells. some time they sub different bearing, but are close to the same bearing. This can some times add to the equation. Some of the pinion bearing have been thicker than stock, thus needing to some math to figure out the right shim or group of shims to make it work.
good luck
Old 03-29-2011, 04:46 PM
Thanks Robbie
.050 in the rear and .070 in front for starting points.
Old 03-29-2011, 05:38 PM
RockRunner's Avatar
Yeah what he said.......................now pump boy pump!!!
Thanks T aka Tom KR0MPS
TLCA #6136
