Old 03-29-2011, 10:42 AM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Default FJ40 on a tow dolly
How well does a 40 tow on a 2-wheel tow dolly? Do you need a heavy-duty one or will a basic one work?
What would you guys say a stock 40 weighs without a top? 3,500 pounds maybe?
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 03-29-2011, 10:51 AM
I've only towed a 40 a few times, both flat and on a dolly. Worked much better on the dolly than flat. Also, the tow vehicle makes a big difference. 3500 without top and doors sounds about right. (stock, without full cage, winch, big tires, etc.)
Old 03-29-2011, 10:54 AM
cbmontgo's Avatar
Cool. I am thinking about towing it to Moab this spring for a weekend trip and doing some light trail riding. I have never been; that CM 2011 thread makes me drool!
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 03-29-2011, 11:44 AM
cbmontgo's Avatar
By the way, if anyone has one of these that I can borrow for a long weekend in exchange for beer or cash, let me know. I am checking Craigslist too, but I really don't want to have to store it somewhere the other 364 days a year that I don't use it.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 03-29-2011, 01:22 PM
I have towed my '40 behind a dolly, as well as many other vehicles. For that long a trip, I'd remove the rear driveshaft, for the sake of your xfer case, transmission, etc. Also, I have found that you need to check/tighten the wheel straps at least 3 times, and more if it rains (they stretch when wet). I have an 'American Tow Dolly' (sold new out of Fort Morgan, CO, for $1120) and my only problem with it is that it doesn't swivel very easily, and this makes the towed vehicle bind and then 'pop' when you go around corners. Very annoying, and it can loosen the straps due to the shock. This dolly is very wide, which is good and overall gets the job done. Newer versions of this dolly have plastic slipper shims to prevent the binding, supposedly.
Just be aware that you get what you pay for, some dollies are very light-duty junk, and most need tires (and 14" heavy duty tires are hard to find and expensive). I have $750 into my dolly after purchasing it used and installing new tires and a rim. I also had to buy a mega-drop hitch insert so that the dolly sits level behind my F350 tow vehicle.
I like that you don't have to register it as a trailer and pay the registration 'fee', but there are times I'd love to have a car hauler. Hope this helps - Steve
Old 03-29-2011, 02:20 PM
cbmontgo's Avatar
Definitely helps. Thanks...
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 03-29-2011, 03:45 PM
I've never towed a 40 with a dolly but flat towed a few times. No big deal there IMO. Snow sucks but not much threat of that again this spring. I thinks its more about your tow vehicle in either case being able to stop the weight.
I took it pretty slow coming down Wolf Creek in the 80/40 combo fully loaded while moving down here. But I rolled right along at 75MPH on the flats. 40 tracked just fine.
Old 03-29-2011, 06:01 PM
cbmontgo's Avatar
I will be towing it with my full-size GMC Sierra, so I think that I should be good as far as tow vehicle size and wheelbase goes.
I checked Uhaul today, and their rates actually look pretty good for dollies. I may give this a shot. Thinking mid-May. Not sure that my stock rig is fit for CM 2011, so I may go on a quieter weekend.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 03-29-2011, 07:03 PM
baileyfj40 baileyfj40 is offline
1/2 or 3/4 ton, the 3/4 will have better brakes.
Mike Koons
77 fj40 lifted locked ready
89 fj62 lifted locked ready
99 F350 reserve hauler
03 F350 crew cab dually the bigger hauler
04 Lance 1121
90 fastiva r.i.p. 336k
01 vw golf daily driver Gone
01 Tacoma double cab
KDDHQ
Old 03-29-2011, 08:56 PM
RockRunner's Avatar
He is right. with the weight of the rig dolly and your gear you will be pushing the max of a 1/2 ton nearly. Biggest issue is snow, trying to stop on a slick road can bring the rear around real easy. Just take it easy and you will be fine.
PS also take it easy on your tranny if it is a 1/2 ton.
Thanks T aka Tom KR0MPS
TLCA #6136
