Old 04-05-2011, 09:46 AM
If they are stock seats, you could always strip them down, get new foam, and recover them with aftermarket replicas. Probably be a few more $$$ than junkyard seats tho.
Old 04-05-2011, 10:23 AM
ianacole ianacole is offline
Send a message via AIM to ianacole Send a message via MSN to ianacole Send a message via Yahoo to ianacole
Excellent!!
Here's a bench on CL: http://denver.craigslist.org/pts/2295096137.html
Old 04-05-2011, 10:55 AM
AHorseThief's Avatar
Default Bench Seat
I'm thinking of going 3 wide for the rear bench seat and mounting it above the wheel wells (need room for the dog). Anybody else gone this route?
Old 04-05-2011, 04:31 PM
Alright, glad to see you didn't leave me hanging for too long
Couple questions that I had for the more experienced fellers in the club:
-Is that a Belleview winch on the front? It doesn't power out, only power in.
-If so, are they typically cable controlled? Or are wired versions available?
-Does anybody recognize that tub color as a stock color?
Old 04-05-2011, 06:30 PM
hard to tell on my little laptop, but it does look like a belleview. if it has a belt type brake on the side and not a toothed one, it is belleview and they are cable controlled. many people have adapted bike cables. as for the body color, i don't think so, but again, hard to tell on my screen
Old 04-05-2011, 07:00 PM
That's a GREAT deal on the Bestop seat...Someone should jump on it.
As for over the wheel well option for the rear seat...The problem you run into is the roll bar and roll bar options and of course the height as which heads will sit. Roomy is not a way to describe the rear of a 40
Old 04-24-2011, 09:16 AM
Nick, you've probably already seen this, but...
http://www.ih8mud.com/tech/oldwarn.php
Old 04-24-2011, 10:03 AM
Default 5687
That 5687 is what I've got on the front of my FJ. IT seems to run strong, but I haven't tested it under load. I need to source the push/pull cables for the clutch and brake. The ones I've got are rusted and the sheathing is shot.
I sent an e-mail to 4-Wheel Drive Center of Minnesota, which according to Mud now owns the rights to see if they can get me something. Otherwise, I'll see what I can find from McMaster or similar.
Old 04-24-2011, 05:16 PM
isotel's Avatar
isotel isotel is offline
Those headers will try and burn your fingers, atleast the set that i had did..
Im glad to see more 40's back in action!, we have a few new 40's in CLC!!
1976 FJ40 TBI350 700R4 Dana300
Colorado Land Cruisers
CrAwLoRadO.com
