Old 04-29-2011, 11:22 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default Emissions Inspection Problem - Need advice
Hi All,
I'm looking for some thoughts on what might be causing my 1996 80LC to fail emissions inspection. Two years ago when I bought it the O2 reading was measured at 2.876. (anything less than 15.0 will pass). This year it blew a 26.67. I replaced the O2 Censor, but it still failed.
The only real modification I've done since I bought it was put bigger tires (285/70/17s) on my wheels (17" FJC wheels). Could the extra revving of the engine needed to get the tires spinning be causing the O2 to blow higher?
Thanks, John
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 04-30-2011, 12:36 AM
John,
I'd start with reading through this thread...80s failing emissions seems to be more and more common every year
http://www.risingsun4x4club.org/foru...ad.php?t=10919
