Old 05-01-2011, 09:39 PM
the sg7900 is a nice antenna but it is big and heavy. I broke one mount because the thing is so heavy and I didn't have a spring on it. IMHO i would also keep a nice 5/8 2m whip. unless you are on both 70cm and 2m you won't see a whole lot of difference in using it.
jmho
Old 05-18-2011, 12:22 PM
CardinalFJ60's Avatar
Default update...
First. Thanks so much for the lessons in this thread.
I got my SWR lowered for all my antennas:
CR8900 (quad band): 1.2-1.4 across all bands
- previously at about 1.7 on 2m/440 and sky high on 6m/10m
SG7900 (big dual band): 1.1
diamond 'slimgainer' (not sure the PN, but it's a dual band): 1.7-1.8
Here's what I did...
drilled a hole in the Gamiviti rack, installed the UHF mount and tested the antennas. it was that grounding isssue - I previously had just a wire, no braid. so attaching to the rack did the trick!!
thanks!!
Old 05-18-2011, 12:31 PM
Grounding! It's always grounding.
Old 05-18-2011, 07:41 PM
xodeuce xodeuce is offline
thanks!!
Sweet action. Your radio is much happier now
-Keith
2004 UZJ100 - stockish for the time being.
Jetta Sportwagen TDI
Sold - 2010 Tacoma, lifted, locked, armored
