Notices
Old 05-10-2011, 10:45 PM
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Default 3rd Row Seat Belt Question
Hi All,
I removed the 3rd row seats from my 80 along with the seat belts. After removing the straps and shackles for the shoulder harnesses, I see there's a large bolt fitting available for me to use as a tie down point. Does anyone have a suggestion on a way to rig up a mount point? Ideally it would be big enough for a strap or a hook set up?
Thanks, John
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 05-11-2011, 11:11 AM
Are you asking about ideas for bolting something that could serve as a anchor point? I think the simplest plan would be a piece of angle iron with two holes drilled in it (one to mount; one for lashing).
Old 05-11-2011, 12:57 PM
LETSROLL's Avatar
I guess I am. I figured I wasn't the first, so I was hoping someone had the parts or a source for parts that I could go get.
LETSROLL
TLCA#19430
Old 05-11-2011, 01:35 PM
how about a climbing bolt anchor. Don't know if the OEM seatbelt bolt will fit but an idea. Pic below.
Metric hoist ring? http://www.mcmaster.com/#hoist-rings/=c9fc9w you'll need to determine the thread size and pitch.
