Old 05-21-2011, 10:11 AM
Crash's Avatar
Crash Crash is offline
Originally Posted by nattybumppo View Post
Passed with flying colors. Replaced the plugs, cap and rotor, air filter, fuel pressure regulator, oxygen sensors, thermostat, but none of that did it. What made the difference was adjustments to the air flow meter wheel. Thanks for all the help and support, Crash. You are the 62 Guru!
You need to update your sig line!
It was obvious that the AFM on Sascha's 62 had been messed with - the silicone seal around the black cap had been removed as had the metal plug covering the air bypass screw. Simply putting the adjustments of that screw and the metering wheel back to settings similar to those on my truck was pretty much all it took to get Dino emissions legal. Amazingly, 23 year old OEM catalytic convertors hadn't been ruined by a year's worth of running extremely rich. There is, no surprise, something to be said for OEM Toyota-spec'ed parts!
