Old 05-16-2011, 09:56 AM
rhyary's Avatar
rhyary rhyary is offline
Default HF on Wipe Out Hill and Poisen Spider Mesa
Buddipole Dipole config - On the Kokopilli Trail
Poisen Spider - HF with hamstick - contacting Arizona.
Wipeout Hill - HF with 1/4 wave 20M (buddipole + threaded rod + quick connect) - contact California, Vancuver, Illinoise and two others
Writing with dry-eraser on the windshield, great idea I learned from Canada's Drew
96 LX450
Albany, NY
http://bestcamptable.com/
KD2KDK
Old 05-16-2011, 09:57 AM
rhyary's Avatar
How do you put text between pictures? I hate it that they all come together.
I prefer to put the description on each picture.
96 LX450
Albany, NY
KD2KDK
Old 05-24-2011, 09:48 PM
They need to be hosted elsewhere to do that. Even in another thread, but so long as they have a discreet image location. Then you can use the image tags to put that path in {img} and {/img} but using the brackets, same key just no shift.
Old 05-25-2011, 01:52 AM
Not exactly
You can "attach" them here as you normally would and then after you have attached them and closed out of the "Manage Attachments" sub-window, look up in formatting section for the paperclip and click on the drop down menu and select the image you want in the place you want it...
Like this:
Name:  Ige Pulling.jpg
Of course, doing it this way you are limited to the 5 attachments per post as where if you do it Nakman's way you are unlimited in the number of pictures per post you can have
Old 05-25-2011, 01:58 AM
Another example:
Name:  Formatting (Large).JPG
Look for the big red arrow on what to click on after you have uploaded your images
Old 05-25-2011, 09:26 AM
Hey I didn't know that, cool!
is that the ledge before wipe out hill?
Old 05-25-2011, 09:49 AM
Another example:
If you weren't our lifetime accountant I'd nominate you for webmaster
Old 05-25-2011, 10:37 AM
Seriously, I didn't know that either! Thanks Jeff!
Old 05-25-2011, 01:41 PM
rhyary's Avatar
Thanks Jeff.
Now I feel better.
96 LX450
Albany, NY
KD2KDK
Old 05-25-2011, 03:44 PM
You know I'm not sure...I'm not even sure where I got the picture but it was the first one I came across and it seemed to fit
I ain't got no webmaster skillz, trust me
