Old 05-17-2011, 11:28 AM
Default How to demagnetize metal
Anyone have an idea how to build a demagnetizer? I have a saw I'm trying to sharpen and all the filings are sticking to a section of it which makes it really tough to work with.
'73 FJ40 - '85 FJ60 - '80 RN47 Hilux - '05 Tundra
KDøGWM
Old 05-17-2011, 11:39 AM
Google "degaussing coil"
http://www.kerrywong.com/2010/01/18/...gaussing-coil/
http://wiki.answers.com/Q/How_can_yo...a_demagnetizer
"The man who does not read has no advantage over the man who cannot read." -- Mark Twain
Old 05-17-2011, 11:42 AM
Rising Sun Land Use Coordinator
Drop it a few times if you can.
Some other ideas - I bet the Black Hole down in Los Alamos had something that would work for this purpose - too bad I'm not taking a trip down there anytime soon.
http://www.groupsrv.com/hobby/about188239.html
"Stay the Trail," "Tread Lightly," and "Leave No Trace" ethics
Rising Sun Bio
1977 FJ40 2F "Brahma" + Lockright, tach, Warn 8274, Power Steering, and Sanden OBA!
2000 Tundra Limited TRD 2UZ-FE
Old 05-18-2011, 08:33 AM
Thanks for the info guys. Do you think a bulk tape degausser would be strong enough to demagnetize a sheet of steel? I found several on FleaBay cheap.
KDøGWM
Old 05-18-2011, 08:50 AM
What kind of steel is it and how thick? A tape eraser probably won't be very strong, so my guess is no. How much are they going for on eBay? If it was me, I'd buy a 500-foot spool of 24AWG magnet wire and wind a monster one. Can't imagine a spool would be more than $20~$40. Other than a huge coil, a degausser is a switch and a plug. I would also put a 100W bulb in series (while you can still get them) to limit the current a little.
Old 05-18-2011, 08:52 AM
60wag 60wag is online now
If you could something like this used:
http://www1.mscdirect.com/CGI/NNSRIT...MTERM=09041500
It'd probably work much better.
Old 05-18-2011, 08:54 AM
Bruce's link is to an industrial version of exactly what you need. It's $150.
That buys A LOT of magnet wire...
http://bbs.homeshopmachinist.net/showthread.php?t=47853
If you want to experiment, I have a Variac you can use.
Old 05-18-2011, 12:47 PM
Heat it up to cherry glowing red
1976 FJ40 with some stuff and some leaks.
2001 Sequoia Limited with heated seats
Old 05-18-2011, 07:24 PM
2nd Childhood 2nd Childhood is offline
A coil of wire is the way to do it. The 100W lamp in series is also a plus. I dont know that the wire (depending on the length) would have enough resistance to keep a breaker from tripping. I would go with that one. Finding the wire is another story, since all copper and precious metals are ending up in a scrap yard. Even metal in use is getting ripped out by thieves these days.
Old 05-19-2011, 09:03 AM
How about the least expensive option to just buy a new saw blade?
Randy Rosetta KDØKWX TLCA #19351 69 FJ40 "Meanie" & 1970 Boss 302 Mustang
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
