Old 05-21-2011, 11:13 PM
Eldorado556's Avatar
Eldorado556 Eldorado556 is offline
Default Adapting 4 Runner seats to a FJ60
I picked up a set of 4 Runner seats to replace my old worn out seats. Has anyone used these seats in an FJ60?
The mounting problem is the width. Removing the 4 Runner sliders isn't possible without taking other integral components along with them.
My solution would be...
Remove mounting brackets from Runner sliders.
Attach a strip of stock front and back that runs side to side.
Attach FJ60 brackets to stock.
Bolt on and go.
1984 FJ60 "Bjorn"
Old 05-22-2011, 11:48 AM
AddictedOffroad's Avatar
AddictedOffroad AddictedOffroad is offline
I have done it. The 4runner seat will sit you a little higher than the original seat, which may not be that big of a deal to you. I basically hacked up the 60 brackets a little and re-use the 4runner sliders. So I basically just welded the sliders to the 60 brackets.
Scotty
