Old 05-24-2011, 01:49 PM
OilHammer's Avatar
Default Building a retaining wall, bobcat big enough?
I have a major home improvement project starting soon, and I'm still trying to pull together some details. As I understand it, I have to put my footings for the wall at least 24" below the grade for frost. At the highest point, I have about 4' of dirt bank before I dig down for the footing. I'm wondering how high the bucket of a bobcat can go and how far forward it can dump. If I come at the bank straight on, can I lift buckets of dirt straight up and dump beyond the dig? Or do I have to dig buckets, then drive somewhere else to dump? Hope that makes sense.... anyway, once the bank is dug back for the footing width, I have to dig down. I'm assuming the bucket is about 4' wide, so I would dig out the full 4' and just build formwork where needed. I have never watched a bobcat do work like this, so I wasn't sure if it was adequate. I hate to go rent one and realize afterwards that it's not going to cut it or take twice as long.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 05-24-2011, 02:36 PM
I would get an estimate from guys who do this for a living. They are so fast and efficient it'll be a treat to watch. I have hired out dirt work like this, and newbies on Bobcats (or most earth-moving equipment) are 2x as slow, or more.
If the estimate far exceeds the rental cost, then you can still consider doing it yourself. If a guy has equipment in your area, this will offset some of the hauling/transport costs, so look for someone already doing this kind of thing in your neighborhood and ask him for an estimate. Just my .02
Old 05-24-2011, 11:17 PM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
I would have to agree w/ Steve on this one. Last time I started moving equipment around in my yard, I flipped the front loader onto its side and had to upright it with my Land Cruiser!!!
The frost line in Denver is more than 24", I think? Point being...that you may have to dig the footer with a back hoe rather than the bobcat.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 05-25-2011, 10:20 AM
Echoing this - I thought footers in Colo. (at least around 7000' elevation, but perhaps lower) had to be 40" deep - about like buried water pipes. Your local zoning/code requirements will specify for sure.
A buddy of mine rented a skid steer and flipped it, and the rental company righted it and said that this happens all the time. Many places will drop the skid steer off at your house, as most people don't a suitable tow rig to get one to and from the rental place. I have owned a tractor with a bucket for 10 years and used a backhoe before, and as fun as they are, they're a lot harder to operate with precision than you can guess, if you're a newbie.
Besides, if you call 'Miss Dig' (or whatever PC term they now call the utility locator service) and the 'other guy' wipes out a gas line, then at least you're not at fault. The guy at my house pulled up a big hunk of unused water line from 50 years ago - kinda scary when they first hit the buried steel line and you don't know what it is.
Old 05-25-2011, 11:48 AM
OilHammer's Avatar
I have run a skid steer before, and also ran a bobcat bucket excavator. I nearly flipped that thing though...my neighbor owned it and let me borrow it to dig up my lawn for sod work. I was running down the street and pushed the "fast" button on the floor to make some time. That thing jumped and nearly ran over backwards on me, then the resulting panic on my end caused it to endo when I let off the gas. Whew...
I've also run a forklift for a few years, but that's really a different animal. Advice taken, but budget really dictactes on this one. I'm getting a few more quotes before I do anything.
The first set of drawings I worked up, I had the footings at 36", but I was talking with a foundation guy in Stapleton and he said 24. 36 is WAY down there...lots more concrete, but at least it makes the wall more stable. The original wall has completely blown out in two spots.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 05-25-2011, 12:38 PM
Are you within the city limits?
City of Denver follows the 2006 IBC with exceptions adopted in 2008. So follow the 2006 code in section 18 for laterally non-constrained walls. Depth under grade depends on how tall above finished and the code has the ratio formula.
IIRC at least two exceptions apply. One is that the city requires permits and inspections for walls taller than 4 foot from footer bottom to wall top. They have also taken exception in 1805.2.1 to set the frost line for Denver at 36 inches.
I think we still have the IBC at home, but they have the current and previous IBC at the library downtown, too. You can find the exceptions on the denvergov.org website in the Building Department section.
Old 05-25-2011, 02:25 PM
OilHammer's Avatar
You are correct, the code says 36" plain as day. What threw me was the foundation contractor telling me otherwise this weekend. I assumed someone doing this work for a living would know it off the top of his head, but perhaps he didn't understand my question. He may have been referring to footing width....dunno. And yes, I must have my wall permitted, stamped, and inspected. The wall itself will be 7' high at it greatest point (to bottom of footing), then a 6' brick fence on top of it.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 05-25-2011, 02:56 PM
I'd give him the benefit of the doubt, but just because he's doing it for a living doesn't mean he's doing it per code. Denver has a lot of codes and exceptions that other cities and counties don't (for better or worse). If you interpret the wording, if you were doing a short retaining wall, the buried depth ratio might not need to be 3 feet deep. In that case you might not need a footing and the frost line requirement is moot. It's possible he didn't understand the dimension of your wall.
Old 05-25-2011, 03:59 PM
Beater's Avatar
Beater Beater is offline
also in the city of denver - don't forget your variance for fencing over 72"
DAMHIK
john (johnny) henley
Old 05-25-2011, 05:11 PM
OilHammer's Avatar
The fence isn't over 6'...it just sort of "blends" with the wall, though there will be a material color change.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
