Old 06-06-2011, 01:20 PM
kurtnkegger's Avatar
Default Winch controller opinions wanted
Went to move my winch on/off switch, and controller plug to operate from my glove box on my 40. When I retrieved my controller from the center console, The whole tray was full of M&M sized plastic chips...Squirrels had gotten to the controller box, and eaten it.
When I was looking for a replacement, I noticed the wireless remote for the winch controls, and was wondering if anyone has used one...is it worth the money...is it any good....should I just stick with the wires...opinions please!
Thanks
Old 06-06-2011, 04:24 PM
What winch do you have?
IIRC, some of the newer controllers, including wireless, don't work with older winches. When I bought a new controller for my XD9000 I got one of the ones with the LED light on it from Warn. It didn't work even though Warn said it would. They had to send me a new updated wiring harness for the box for it to work. As I recall, I would have had a similar problem with the wireless system.
For me, the amount of winching I do would never justify the cost of the wireless system so I went with the age old wired controller. And frankly, the Warn controller with the LED light is pretty gimicky...You're better off with a head lamp or flashlight if you are winching in the dark so if I could do it over again I'd just get the old school one.
If you are going to the trouble of relocating the plug, why not just do an in/out switch in the cab and forget about a new controller all together?
Old 06-06-2011, 08:03 PM
Keep it Simple.
Old 06-07-2011, 09:02 AM
FJCDan FJCDan is offline
I thought about a wireless remote when I bought mine, the salesman said that sometimes there is a delay that might cause a safety issue while winching.
Old 06-07-2011, 10:02 AM
ScaldedDog's Avatar
I still carry my plug-in winch controller, but I wired an in-cab switch so I can run the winch whenever I want. It was cheap to do, works great, and I love the capability. I used a winch switch from 12voltguy.com to arm the winch, and a 3-position Carling switch to control it.
Mark
http://www.scaldeddog.com
Old 06-07-2011, 10:07 AM
I would go with the wired in-cab setup, I have the same as Mark. Also, don't throw away the chewed up winch controller. It would be super easy to get a small plastic project box from Radio Shack and move your switches over to it or even install new switches if the old ones were damaged/
Old 06-07-2011, 08:39 PM
2nd Childhood 2nd Childhood is offline
I used (2) normally open pushbutton switches from "Checker" mounted them into a 3/4" electrical LB and used an old school Trailer harness (4-wire) that worked great for around $8.00. I had some wire laying around, so I made it work. I placed about a 20' lead on it, just in case I wanted to use it in the cab or outside. Its kinda ugly but it will work.
Old 06-08-2011, 04:56 PM
Thanks for the replies. I appreciate the comments and ideas you have given me. I've decided to go ahead and rebuild instead of going wireless. I don't use my winch too often, and started thinking about not having batteries for the controller when I needed them most...That would just be my luck...so I'm opting for the tried and true...hard wire option. The wire was left fairly un-scathed, but still took some damage from the chewing.
Here's what those little fuzzy tailed rats did...
Old 06-17-2011, 01:48 PM
OK, here's what I've done...Went ahead, and wired up a toggle (20amp) "temporary on" switch. When pressure is not applied to the switch, it centers, and stops the connection. Got a box from Radioshack, drilled holes for the switch, and cord. Inserted a grommet on the cord side to help protect it.
Old 06-17-2011, 02:03 PM
Openned the winch controller box, and removed the switch, and the cable connector, moved both of those to go through the glove box wall. Jumpered the power to the winch solenoids to determine which one was out, and which one was in, and wired the controller box accordingly. Put a cover plte on the open holes left behind after the switch removal. After wiring was complete, I reinstalled the cover 180 degrees from what it was to keep it clean looking.
Now my controls are accessable through the glove box! I like to wheel with he windshield down, and since my controller box was under the hood, it made it a pain to get to the winch controls.
Not anymore! pretty happy with the results...
