Old 06-07-2011, 10:20 AM
Default Rust repair advice
I am going to attack the rust on the 40 this summer. My fenders are starting to rust at the typical spots, I have rust at the bottom rear of the rockers, and I have rot along the rear sill and at both rear corners of the cruiser. Drivers side floor is swiss-cheesed as well, as are the door bottoms... all four. Other than that I am SOLID
For those of you who have BTDT, I am trying to decide which sections are easiest to ease into body work again. I am going to cut out the crud and weld in new steel. I was wondering what you would suggest for recoating the welded area's? I am thinking stripping the section several inches, cutting out the rot, fitting and welding in new steel, grinding smoothing, body filller to smooth, epoxy sealer, primer, top coat... does that sound about right? My only heistation is the time it may take to get around the whole truck and habving the primer exposed for a long time before a repaint.
I have used some of Sherwin Williams over the counter canned products in the past with good success, is there something else local that would better for the spray stuff?
Also, I am just running CO2 through my MIG and I am wondering if I ought to bite the bullet for the argon-co2 mix? I have heard it burns a little cleaner. Also what gauge wire should I play with for this thin sheet metal? .025"?
Thanks in advance, I am not going for showroom quality but I don't want a gobbled mess when I am done either.
Old 06-07-2011, 10:31 AM
subzali subzali is online now
Start with the least visible panels/parts. Personally I would probably attack the driver's floorboard first.
And think about this - if you screw up the fenders too badly, they are still available from Toyota, so maybe you could move there next
Old 06-07-2011, 10:35 AM
I dunno if I'm qualified to give advice, but I can say that if I could repair the rear sill with reasonable success, you'll have no trouble at all. I've got some of the same body issues as you, and I've got floor boards on my radar, although I think I'm going to try the patch panels from Pacol (or similar source) rather than trying to repair what I have.
AHorseThief's Avatar
Default Weldering
Haven't started weldering on the 40 yet, so I can't help you with where to start, but as far as wire and gas my plan is to use .023 wire with 75/25 gas.
Old 06-07-2011, 01:36 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
There is a product called Eastwood Rust Encapsulator that is easy to apply and would protect the exposed steel while you work on other areas. From what I remember, it is a lot thinner and easier to apply than POR-15.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 06-07-2011, 02:19 PM
I have spent the last two-ish years fixing the body on my 1980 FJ - using a lot of steel that I welded in, as well as a PACOL rear quarter panel. I used .030 wire and 75/25 and set the welder to a pretty high current and low feed. I was generally happy with how the welding went, but after fixing 40-odd rust holes, it's very tiring after a while. See photo of the rusty bits I cut out - notice the screwdriver in the pix for scale. The OEM quarter panel I removed is not in the photo.
Matt's advice is solid - start with floor pans and places that allow you to learn the finer welding points without having appearance be an issue.
RE: PACOL - the first two full rear quarter panels I ordered were literally unusable due to grossly inaccurate production tolerances - (the hard top could not be made to fit). PACOL sent me another set at no cost. The second fender (the one actually now welded to my truck) was better in one critical way, but horrid in others. After installing the pass. side, I just fixed my OEM driver's side fender, rather than risk learning how bad the other fender was.
I have 3 spare PACOL rear quarter panels ('79-83 era) in my garage, if anyone wants to see them. I did document all my issues and sent many annotated photos to PACOL showing them the problems.
I would buy only CCoT repair panels and simply try to fix as many holes and problems that you can using flat steel stock. Repair panels that fit perfectly would be really neat, but fiddling around with mine added months to my job and a high stress level.
I wish you the best in tackling this - if my bondo-bucket could be rehabbed, anyone's can.
Old 06-07-2011, 10:41 PM
Thanks guys, I appreciate it. Wow Steve, thats a lot of rust to kick out of that cruiser. Good on you bud!
Old 06-07-2011, 11:02 PM
Originally Posted by Rezarf View Post
Wow Steve
x2. That's a lot of bits.
Old 06-08-2011, 06:53 AM
Thanks - in some ways, that rust scrap photo makes it look worse than it really was. And in some ways, it *was* bad. My hat is still off to the east coast crowd who start with much worse. Here's the result as of 2 days ago's wash job:
Old 06-08-2011, 09:24 AM
steve, what kind of front bumper is that?
