  #101
Old 02-15-2012, 06:11 PM
And then I took a gander at my fender to see how/if I could use existing holes to mount the manifold etc. And then I realized that my fender has been cut and it's rotting out anyway, so if I need to drill more holes it won't hurt anything
Rising Sun Bio
  #102
Old 02-15-2012, 06:13 PM
And then I looked for places to mount a little inlet filter. I didn't have a chance to cruise by the auto parts store tonight to check out their options and hopefully to see what the best way is to mount it, so I'll need to do some more headscratching.
I'd hate to drill into the air cleaner, but there are some little screws that I could probably use to mount a bracket that holds the air filter. A little bendy bendy of some sheet metal and it would probably be good to go.
Rising Sun Bio
  #103
Old 02-15-2012, 06:26 PM
That un used fuel filter would make a great air filter!
Colorado Trail Patrol
Stay on the Trail!
  #104
Old 02-15-2012, 06:29 PM
And here's some stuff I got. Still have to get an air hose, might get a cheap one for now and see how long it lasts. It won't be dealing with really cold CO2 like some cheap hoses so maybe it'll be ok for a while. :shrug:
Also learned something new besides the 3/8" vs. 1/4" air connections that we discussed a couple pages back - there are different ends for the quick couplers. I asked the guys there and they said I/M is the most common. T was the other type. So hopefully that's correct.
Upper left: Quick-coupler: $4.99
Upper middle: Quick-coupler plug: $1.99
Upper right: Air chuck: $2.99 - Returned this to get one with a clip.
Middle left: 150 psi relief valve: $10.29 - I guess this might pop off every time my compressor cycles - we'll have to see. Or maybe I'll still get an adjustable pressure switch and keep the pressure down a bit. The pressure switch Marco gave me is huge - maybe I'll just pass it on after I'm done
Middle: 5/8" SAE flare to 1/2" MNPT 90 degree elbow: $8.49 - for the suction side.
Middle right: 1/2" SAE flare swivel: $9.99 - basically two 1/2" flare nuts with a short piece of tube in the middle, pre-fabbed for the discharge side.
Bottom left: 5/8" SAE flare swivel: $9.99 - for the suction side.
Bottom middle: 1/2" SAE flare to 3/8" FNPT: $4.29 - I can get a Viair 3/8" hose and thread it right into this connection on the discharge side. - Returned this because I needed an elbow - not enough room.
Bottom right: 200 psi pressure gauge: $7.99
Total: $61.01 $53.73
Fittings add up
I still need to get an air hose and some barbed hose connectors (Ace didn't have the right size/configuration I needed), plus the manifold etc. obviously. Getting there. Thanks for letting me share every step and every thought, probably annoying to some but hey it's your fault for clicking on the thread
Rising Sun Bio
  #105
Old 02-15-2012, 06:31 PM
That's on the breather hose from my diffs. Guess I should probably clean that up some
Rising Sun Bio
  #106
Old 02-15-2012, 06:33 PM
I/M is very common. If your cheap hose breaks/blows you can borrow someone elses that way! Seriously it's very handy to be able to swap attachments!
Stay on the Trail!
  #107
Old 02-15-2012, 06:35 PM
Yep, that's exactly why I wanted to get it right. I'm learning a lot about compressed air systems by doing all this, I thought all domestic compressed air systems were pretty much created equal. Shows me
Rising Sun Bio
  #108
Old 02-16-2012, 01:12 PM
Bought some more stuff today:
Air Hose (50 ft PVC) from Lowe's: $14.02
Manifold from Amazon: $24.02 after shipping
Filter/Coalescer from Amazon: $79.49 after shipping (thanks Nick/AHorseThief! ) - vs. $115 for the one on Kilby's site. This one is made by Interstate Pneumatics, has a metal bowl, and is rated to 300F. Hopefully I don't melt it like Marco did his
Inlet Filter from Amazon: $30.15 after shipping vs. $28 for the one on Kilby's site. This is the same manufacturer (Solberg) as the one on Kilby's site and I'm assuming it's the same model. It has the same thread connection and is rated for 12 scfm. Heck, the one on Kilby's site may be the one rated to 10 scfm, so if that were to be the case this would be an upgrade. The next largest one is rated to 20 scfm and has a 3/4" NPT connection, which I didn't want. Hopefully this will work.
Air Chuck w/clip from Amazon: $10.37 after shipping
1/2" FNPT to 5/8" hose barb from McMaster-Carr: $7.52 - this hose barb size is hard to find, but it's what I wanted because I don't want the hose to collapse. Maybe it will anyway and I'll have to redo the suction stuff .
Had to stop by Ace to correct one of my receipts, return some stuff, and buy some more stuff
Had to get a 1/2" flare to 3/8" MNPT 90 degree elbow: $4.49
Had to get a 3/8" coupling for above because they didn't have the above in FNPT: $4.29
Another quick coupler/plug set: $7.49
A couple hose clamps: $2.58
Some sheet metal for mounting the inlet filter: $6.29
Running total: $236.92 - boy it adds up! More expensive than a Viair, but not yet more expensive than 2
Still have to buy a pressure switch and leader hose with check valve, but that should be about it except for some random street elbows, nipples, suction hose, and mounting hardware. I'll need to find the receipt for the belt, sleeve bearings, compressor oil and teflon tape I had to buy, and the compressor was donated for the project but can be had anywhere from $30-$50 at a junkyard.
Rising Sun Bio
  #109
Old 02-17-2012, 09:13 AM
Can someone school me on relays for belt-driven compressors? Marco gave me some input yesterday, but still not convinced I need a relay...
Also, do I need to worry/account for the compressor starting up against a pressurized manifold? Do I need a bleed-off valve?
Rising Sun Bio
  #110
Old 02-17-2012, 09:37 AM
Mine doesn't have a bleed off and it works fine. Bruce runs a bleed off.
