  #171
Old 02-29-2012, 10:08 PM
Very low quality video:
OBA Test 1
EDIT: Thanks Jacket!
Crossposted to MUD...
http://forum.ih8mud.com/winching-rec...7-2f-fj40.html
  #172
Old 02-29-2012, 10:39 PM
AHorseThief's Avatar
That's a whole lotta shiny new in that 35 year old truck. You'd better hurry and get it dirty so it matches everything else.
Nick Kimball
'73 FJ40 Rockin a 327 SBC
  #173
Old 03-01-2012, 12:01 AM
Is this what you're after?
http://www.risingsun4x4club.org/uplo...90%20small.wmv
  #174
Old 03-01-2012, 07:45 AM
Thanks Matt! I'm still not sure how to properly copy the url over, but I used yours and it works fine!
  #175
Old 03-01-2012, 08:32 AM
2:45
That's how long it takes, at 900 rpm, to take a 31x10.50R15 from 12 psi to 36 psi. Not a barn burner, but respectable.
I have a leak at my pressure gauge, but other than that, all systems appear to be nominal. I'll post some pictures, and maybe a video, later.
Glad you got it going! That's about a normal time to fill a tire from most sources. Think about how tiny the actual hole in the valve stem is! On my 40 I have dual stems. The second stems are Monster valves. They will air the 40's down from 25 (street pressure) to 4# in about 20 seconds. They will air back up the tire in about 45 seconds! CO2 seems to air up quicker too than OBA. I think it's probably because of the dry gas.
....looking for a web pic I found this article....pretty much sums it up...
http://www.off-roadweb.com/tech/0909...ves/index.html
  #176
Old 03-01-2012, 08:51 AM
Cool, yeah I can see that especially for larger tires, having a less restrictive valve would help. CO2 also has the advantage of all of its pressure potential available to quickly inflate the tire. Same with an air receiver. I need to start thinking about where to put one of those now...
  #177
Old 03-01-2012, 09:36 AM
Sweet you got it going! Put a brick on that gas pedal for faster performance... right around 1200 is a good sweet spot IMO, 2000 is the upper limit. An ice scraper between the pedal and driver seat can make for a good hand throttle.
  #178
Old 03-02-2012, 04:46 PM
I just have to add this: I don't know why it takes me so long to do stuff like this - I looked over Marco's thread and he installed his in an afternoon. Mine took me two weeks +/-
Oh well. It's just the way I am I guess.
  #179
Old 03-05-2012, 04:37 PM
You could have brought it over to my place and it would still have been in pieces this fall so I'd say you did good
  #180
Old 03-11-2012, 12:08 PM
Took Jeff's welting and made some cuts so it could make the bend. We'll see what happens here. I might have to come up with some sort of hold-down so the pipe doesn't bounce out of the slot. It's ugly for now but if the theory works I'll clean it up some.
