Old 09-01-2011, 04:40 PM
Just wanted to add a couple links, one of which came from rusty_tlc on MUD:
http://www.grungle.com/endlessair.html
http://www.jeepaholics.com/tech/OBA/oba.htm
http://www.kilbyenterprises.com/kits.htm
The SD508 supposedly is a 5 piston compressor which can put out 9cfm and 300 psi. I think the SD510 (which I have) might do slightly more cfm.
Rising Sun Bio
1996 FZJ80 1FZ-FE factory lockers + Safari intercooled turbo, CDL switch, cup holder, Metric TLC leather, heated seats and JDM switches
Old 09-04-2011, 03:03 PM
LARGEONE's Avatar
LARGEONE LARGEONE is online now
I bought a VERY inexpensive military HUMV hand throttle and it works awesome. I had to modify it slightly to fit my 80, but the way that it adjusts is very nice compared to the toyota one that was available. I think I might have paid like $12. I really like the way you can turn the handle counter-clockwise and dial in the RPMs to whatever you want.
Paul
White 2008 GX470 - Nearly Stock
"I drive an ECO-FRIENDLY FZJ80...It's got a salvage title which makes it a REPURPOSED/REUSED/RECYCLED vehicle. Therefore, don't mess with me when I park in the "Reserved for Green Vehicle" spots in Boulder!!!
http://www.vrbo.com/322094
Old 09-04-2011, 05:46 PM
A hand throttle is good but so are power seats.
A trick I learned from Nakman: You grab your trusty snowbrush/ice scaper and rest one end on the accelerator peddle and hold the other end in front the driver seat, then move the seat forward with the power switch. Stop the seat when you have achieved optimum engine rpm for filling tires with the onboard air.
  #24
Old 09-04-2011, 09:37 PM
Um, FJ40 guys, no power seats
Rising Sun Bio
  #25
Old 09-04-2011, 10:51 PM
AHorseThief's Avatar
Hand throttle or power seats and an ice scraper...which sounds like the sweeter upgrade?
  #26
Old 01-29-2012, 04:58 PM
Default Baby Steps...
Okay, I warned you guys this would be slow...
Got the compressor wired in today. Yep, that's it.
When I got back inside, I was like, "alright, now all I gotta do is wire in the pressure swi---"
So not quite done with wiring it in yet, I have to see what pressure switches I have lying around and figure out how I want to wire one in.
On the other hand, I ran the compressor briefly, so at least I know it works It blew a 2A fuse, so I put a 5A fuse in there and so far so good. That wobble plate sounds a little funny, just different from other compressors I'm used to. I put my finger over the outlet port, not really sure what to expect, but it seemed like the flow was lower than I thought it would be - maybe that's because I was at 800 rpm or so. I can see why a surge tank would be a good idea. We'll see how it goes, especially if I run it at a higher rpm. :shrug:
I still have to source an inlet filter and oiler (have to figure out the thread size I guess first) and pretty much all of the pressure side plumbing components, and figure out how to mount all of it up. But getting it to run was a big step
Rising Sun Bio
  #27
Old 01-30-2012, 11:20 AM
Does anybody have any input on what on OBA compressor should feel like at idle? It feels like if I were to put my hand up to my face and blow on it, it doesn't feel like 90 psi shop air coming out of an air nozzle...
Rising Sun Bio
  #28
Old 01-31-2012, 09:17 PM
Well, got a little progress tonight. A couple days ago I noticed that my electrical connectors were pretty disorganized, so I thought that I should try to fix that a bit. I know you can buy variety packs of this stuff, but I've acquired these a little bit at a time, so this will work pretty well.
Rising Sun Bio
  #29
Old 02-01-2012, 12:39 AM
Not a clue Matt but if you don't get an answer, you could always swing by sometime and we can fire up my 40 and the York and compare
  #30
Old 02-01-2012, 01:04 AM
A compressor by itself (even your home compressor) only puts out 10 CFM (few CFM more or less) Add in the storage tank and now you "compress" the air and create pressure. Just like the air from your mouth....open your mouth and breath out air onto your hand.....meh. Now blow that same air through your puckered lips and you can feel it... same air....less volume more pressure. Try sealing off the output hole from the compressor with your finger....bet ya cant.
Colorado Trail Patrol
Stay on the Trail!
