  #61
Old 02-07-2012, 07:41 AM
You'll hate this answer! The cheap arse "yellow" coils suck! They kink and when cold they break. The high grade coils you get from truck supply shops are good. (Ige is a good source!) The hoses from Powertank and Ultimate are really good but pricey! If you use regular air hose avoid the plastic crap as It is a pain in the winter and it wears out pretty quickly.
Yeah, the ones at the hardware store are PVC.
1/4" or 3/8"?
  #62
Old 02-07-2012, 08:03 AM
yeah, The Ones At The Hardware Store Are Pvc.
1/4" Or 3/8"?
5/16"
  #63
Old 02-07-2012, 08:27 AM
5/16"
Brat
  #64
Old 02-07-2012, 09:50 AM
Brat
Your not running a storage tank....1/8" will easily carry 10cfm!
  #65
Old 02-07-2012, 09:52 AM
Actually, why aren't you running a storage tank?
  #66
Old 02-07-2012, 10:07 AM
Not yet
Okay, understand your point
I'm just trying to get it up and running for now. I'll worry about a storage tank later. Figured it wasn't really needed for airing up tires alone, but eventually it will be part of the plan.
  #67
Old 02-07-2012, 10:15 AM
Ok got it. When I did my OBA setup I learned 2 things: the first was the fewer airline connections the better- at first I had T's all over the place making my sliders into air tanks, multiple places to connect the hose to, etc. 6 months later I was chasing leaks like mad, my breaking point was I actually had a "blow out" on the way back to Reno, just after we aired up at the end of Rubicon- sounded like someone shot out my tire.. but was just a red air line popping off that had worked itself loose. I was happier when I cut all that out and just ran an air hose from the manifold back to the tank, bypassed the sliders, etc.
The tank is the second thing. In addition to more meat behind airing up tires and running tools, you can shut the truck off, and still have air available. So later on at camp you can top off a bike tire, fill a football, blow dust out of a radio, etc. You're not going to fill a tire from it, but having a little air around can be handy.
  #68
Old 02-07-2012, 11:10 AM
The air tank also acts as a buffer for the compressor. You'll be able to fill tires much faster with it, maybe twice as fast.
  #69
Old 02-07-2012, 06:48 PM
black95's Avatar
black95 black95 is offline
I still don't get that, and personally think it's a myth.
I run 37's and a big Viair. The 37's will drain the tank almost immediately, then essentially, you're running air straight through the tank to the tire, everything having the same pressure when all hooked up. so why bother with a tank? At best, your tank is big enough to hold higher pressure, then you're pumping air into a 75 PSI tank when it would be easier on the compressor to pump air straight into a 30 PSI tire. I don't carry air tools because I think that's just silly and adds weight. A 4-way is much lighter and honeslty, how long does it take to spin off 6 lug nuts???
Luke
KFWD
  #70
Old 02-07-2012, 07:14 PM
Are you going to put a pressure switch but in?
