Old 07-22-2011, 12:41 PM
Default Installed a new steering wheel, now it honks when I turn
Ahhh, I installed a Grant Steering wheel and now I get a chirp/honk when I am driving slow and crank the wheel (think parking spot turn). So far, I have offended several people and had a few 1 finger waves The worst was a few weeks ago when a neighbor girl and her friend (who are about 15) were coming back from the pool and I was turning into a spot when it did a double chirp... yup, right there as her pops was dropping her off. Gotta' fix this asap.
I know it is a short some where and it appears to be happening as a result of "flex" in the wheel as it doesn't happen when I am careful about just spining the wheel. If I press on the wheel hard even at a stand still it will chirp.
I have pulled it twice now to try to see what's going on and I have added shrink wrap to the connections to cover all the exposed connectors... still I get the chirp.
FWIW, at night when the lights are on, I can get both turn signals to blip at the same time the horn chirps. Something is grounding out and connecting the circuit but I can figure out what. Any guesses?
For now, I have disconnected my horn but that is NOT a long term solution.
Thanks-
Drew
Old 07-22-2011, 12:52 PM
Are you using the security coupler or the regular, permanently bolted on knuckle? Not sure it matters, though it did in my case.
I had a weird horn beeping problem once that turned out to be the horn switch wire was pinched between plates. The squished insulation wasn't completely cut and so a little torque on the wheel out make and break the short. If you put in the security kit there is a plate held in with Allen screws in the column on top of the regular adapter, this is the wheel retention gizmo.
The wire got caught between this levered plate and the center-nut-to-three-bolt plate when I installed it. It was obvious when I opened it back up, the wire was flat like pancaked.
Old 07-22-2011, 01:04 PM
I am not sure of the difference, whats a security coupler? Its a splined shaft with a bolt, both my wires are clean and not pinched.
Drew
Old 07-22-2011, 01:05 PM
Sorry Drew, I'm not much help...
When I installed my Grant (w/ the security dealyo) I had the opposite problem of no horn...Turned out to be the relay.
You would know if you had the security dealyo - separate unit/cost
Old 07-22-2011, 01:06 PM
Romer Romer is offline
I know this isnt any help, but this made me think of Henny Youngman and his answer would be
"then don't turn"
Old 07-22-2011, 01:14 PM
Drew
Grant has an accessory that goes between the steering column knuckle and the steering wheel that lets you take the wheel off.
The regular adapter is the part you bolted to the splined steering column that has the 3 bolts.
The anti-theft part looks like this.
If you look in the middle of the security part there are two buttons. This is where the steering wheel horn button makes contact. Anyway, there are wires for it (which you can see sticking out the back in the photo), which I think would have to be the same as the regular adapter. I pinched when I bolted it down.
Old 07-22-2011, 01:15 PM
BTW, the 3 bolts in the Grant system like to loosen, make sure to check them periodically and use blue Loctite!
Old 07-22-2011, 01:57 PM
Dave, I dropped out the part in the middle on your first pic, it looks like a phonelic spacer of some sort. I read on Mud that it wasn't needed. Maybe it is...
Drew
Old 07-22-2011, 02:12 PM
Drew
Uh, yeah, that's the horn button contact ring. :-) That makes contact with the heads of the three bolts (which are ground) when you push the center cap on the steering wheel (it fits inside the cap, there are three dimples in the cap to retain it). Without it I suspect the wire coming from the steering hub is just flopping around inside the steering column, randomly shorting... Whoever said it wasn't necessary must have been using a different steering wheel adapter or something.
Old 07-22-2011, 02:36 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
just salute them back..
TLCA # 20314
Step by Step Bed Bob
