Old 07-28-2011, 04:25 PM
CardinalFJ60's Avatar
Default should I be on the CC as much as I am?
Since we 'light up' the whole state when on the connection, I'm thinking it makes more sense for me to really just monitor and use the local repeaters like the CRA, DRC and others. I've been programming my 8900 lately and have seen lots of Front Range local repeaters.
Driving the I70 corridor I would tend to use the connection as the main commuication channel, but running around town, commuting, etc. I'm thinking I may tend to hit the CRA repeater more often?
I dunno...any discussion on this? I mean the CC isn't that busy....
Old 07-28-2011, 05:02 PM
Default just to add...
so...for the record, I'm/we're not rag-chewing or anything - but for local contacts outside effective simplex range, I'm thinking about moving to a more local denver/boulder repeater instead of lightin' up CO.
Old 07-28-2011, 06:01 PM
CO Hunter's Avatar
IMHO, not lighting up all of CO, when other options are available, would seem to be good amateur practice. But, as you said it is not that busy. I use local repeaters down here, similar to how you have described, when available.
To the other topic. Again, IMHO your group made three mistakes. 1) Illegal transmission 2) Use of profanity 3) Not apologizing. The others did not need to identify until end of transmission and every ten minutes. I know folks get lax in the boonies on simplex but when others are around I would identify. Amateur has a higher standard than CB and we need to police ourselves.
Old 07-28-2011, 06:31 PM
Mistake #4: Broadcasting
It's generally considered bad form to transmit with no expectation of a reply. The APRS beaconing is marginal, but it's not eating up much bandwidth and 144.390 (on 2m) is universally accepted as a dedicated frequency. Another accepted 'broadcast' are HF beacons that people use to determine propagation.
It's also possible since you were moving that you came into range of their conversation. You are supposed to listen a while and check that a frequency is not in use before transmitting. But if they were mobile they could be guilty of that, too.
Old 07-29-2011, 10:10 AM
Groucho's Avatar
Groucho Groucho is offline
Default Colorado Connection
Shawn,
I think you have a good head about doing what will show others that you are a great HAM operator. Don't stray too far from that and you'll be fine.
My take on the "normal" use of any repeater is that we must continue to use the available bands we have so that there is less reason to take any of it away from the Amateur community. While rag-chews might seem inappropriate at times on the Colorado Connection due to its state-wide range, if you and some guy from Salida or Gr Junction want to talk about some adventure you had by all means have a rag-chew. That is why we have the use of the frequencies, to connect with other HAM's. "Normal" etiquette applies, so allow for break-ins and the like. I am not advocating the improper use of the Colorado Connection, but more advocating proper use of available frequencies under the intent for which they were implemented. From the Colorado Connection's Website:
The Connection serves many communities as an emergency communications backup. All licensed amateur radio operators with two meter privileges are welcome to use the system and our volunteers support the Connection for the love of amateur radio.
I personally think that the emergency portion of the Amateur community has strong benefits, but also has slipped into a slightly over-pushed category too. The Amateur Radio Service is not solely for use by/for emergency circumstances. That is a very important part, but too often because that is an easy way to show the value of Amateur Radio as a service to the public, it rises to the top that emergency communications are the only reason why Amateurs have their frequency privileges. The Amateur Radio Service has many facets for why it is important, not just emergency communications. Historically, it has been the proving ground for many of the things in our lives today that we take for granted.
From FCC Part 97:
97.1 Basis and purpose.-
The rules and regulations in this Part are designed to provide an amateur radio service having a fundamental purpose as expressed in the following principles:
(a) Recognition and enhancement of the value of the amateur service to the public as a voluntary noncommercial communication service, particularly with respect to providing emergency communications.
(b) Continuation and extension of the amateur's proven ability to contribute to the advancement of the radio art.
(c) Encouragement and improvement of the amateur service through rules which provide for advancing skills in both the communications and technical phases of the art.
(d) Expansion of the existing reservoir within the amateur radio service of trained operators, technicians, and electronics experts.
(e) Continuation and extension of the amateur's unique ability to enhance international goodwill.
While the Colorado Connection does provide a great service for emergencies, it is not solely used for that purpose. I know that some outside our RS group who listen to the Colorado Connection during Cruise Moab time of year have hinted at the fact that we use the frequency heavily, I believe we use it in the spirit for which it was intended. We give traffic updates, we ask for help during breakdowns, and we also give others information as to our whereabouts.
The main thing I will repeat is proper use of the frequency. Don't be the guy who treats Amateur Radio 2M VHF as glorified CB. Profanity has no place here. Proper etiquette, mutual respect for other operators and enjoyment of the service do.
I realized I missed out on some of this thread, but I hope that covers most of what was desired out of a response.
--Choose Wisely--
Old 07-29-2011, 10:26 AM
Glad to see you are a member here:
http://www.w0cra.org/
why not use those machines for around town?
I too am surprised by how dead CC is most of the time. I typically like trying to use it to find somebody then move to simplex or a local repeater if possible. That said, I actually enjoy hearing you on CC talking to folks about various things. I get a kick out of walking out to the garage and hearing MZE out there "hey I know that guy!" and I think the people on the other end like making the contact. I usually don't pipe up because my radio in the garage has some mad static going on on that frequency.. plus it heats up a lot. I think thh filters are wrong for that frequency.
Old 07-29-2011, 10:40 AM
Caribou Sandstorm's Avatar
Shawn, my apologies for mucking up your post/thread.
I mentioned my recent interaction because it seemed relative in a way, as I was on low power and seemed to have a pretty far reaching foot print.
Learning experience for me, for sure.
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 07-29-2011, 10:46 AM
I think people are a little intimidated by the CCR (and repeaters in general) and the coverage. Don't be, no reason for it. Remember we key the mic to test our gear and practice our skills for the rare time we might have to count on it. If you're in an accident you want to know that you have the right frequencies and tones in your radio, that the gear is sound and the coax is unbroken and you want to know how to use it without thinking about it. That comes from regular practice and testing.
Repeaters on FM VHF are way better than bothering with simplex, which is why first responders use them. It's fun to optimize for point-to-point distance, but in an emergency you will want to know how to work within a net on a repeater so jump into the round robin when a subject strikes your fancy. So never worry about using a repeater, if you don't hear anyone on the CCR, perfect time to put our you call and check it. You are doing the repeater owner a favor, really you are. Call out for a ham in GJ or Salida or the Springs, you are testing the links, too.
Plus there are blessedly very, very few conceited hams and they almost always sit waiting on 14.272 or 14.313 to pounce on a new call sign or someone not perfect in their eyes. Heck with them. There are dozens of others listening who are happy to encourage and Elmer you.
There are around 2 million amateurs worldwide and 1,999,995 of them just want to shoot the breeze about your Cruiser, what you do for a living, the weather and most of all radios and operating! Never forget that everyone in the hobby went out of their way to get a license and set up radios, so it really is about the enoyment.
Old 07-29-2011, 11:55 AM
Yep...for $25 I wanted to support the local group...then I discovered a bunch more! I'm interested in learning/using the autopatch stuff since my wife isn't a Ham.
Well, this has turned into a good discussion. I've made some 'acquaintences' on the CC (ab0em, 'mike-sierra-papa", AFA etc). Those of you who listen to the CC know who I'm talking about. it's cool to announce I'm mobile, and have someone reply, chat for a bit, then go back to monitoring. for safety reasons, I think it's cool to have a quasi-network on the airwaves.
That being said, I gravitate to the Connection mostly 'cuz I know lots of you jokers will be monitoring as well. And I too, love hearing 'nak' and 'gwx' out there catching up a little.
CRA (the 225 repeater) can get busy, same with the .145 repeater. I'm going to check out some of the others in the area (denver and to the north) and chime back in with some other options that maybe I'll add to the mix.
Old 07-29-2011, 01:50 PM
Bruce Miller's Avatar
Default Mega Link
If you really want to reach out and touch someone, along the I-25 corridor from Pueblo and south it is possible for the mobile operator to hit the repeater on Sierra Grande mountain in northeastern New Mexico. New Mexico's version of the Colorado Connection is the Mega Link system. Headquartered in Albuquerque, the Mega Link system connects all of New Mexico, western Texas, western Oklahoma, eastern Arizona, and southern Colorado. The repeater callsign is NM5ML. Sierra Grande's frequency is 147.28 with a positive shift and a 100 offset. As the crow flies, it is about 150 miles from Pueblo to Sierra Grande.
Nice to know for the op traveling south on Interstate 25.
WDW/ZF2KN
1966 FJ45 LWB Pickup
1985 BJ74 RHD
2006 UZJ100 with HDFT-E/H151F
2008 URJ200
