Go Back   Rising Sun Member Forums > For Sale + Help > Vendor Market Place
Old 08-04-2011, 10:20 AM
Default Just differentials (JT's) Chromoly rear axle shafts
Anyone else get this email from JT's the other day? I assume it's a new product offering for full float Toyota axles.
Nitro Gear & Axle Chromoly Full Float Rear Axle Shafts for Toyota Landcuiser & Custom Applications! Now available!
Toyota Trucks & Landcruisers are well known for their strength & reliability all over the world. Out of the box they feature some pretty great drivetrain, but they do have their limits. The factory 30 spline full-floater axle shafts are not built to withstand the added stress of larger tires and heavy offroad use. Nitro Gear & Axle has addressed this by offering a range of Heavy Duty Chromoly Rear Full Float Axles. The only Full Float rearends offered by Toyota in the US were in Dually Pickups, and FZJ80 Land Cruiser, however Full float axles were much more popular worldwide in all models of Landcruisers and are commonly used as an upgrade for US models and otherwise.
Chromoly Full Float Rear Axle Shafts for Toyota Landcuiser & More:
-Made in USA
-High strength Chromoly Material featuring State of the art machining, heat-treating and polishing processes for uniformity and ultimate in stenght.
-Wide application range suiting most Toyota pickups, 4runners & Land Cruisers as well as custom applications
AX TFF-FJ40 $449 pr
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FJ40 REAR, FULL FLOAT ONLY! (PAIR)
AX TFF-FJ60 $449 pr
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FJ60/HJ60 /62REAR, FULL FLOAT ONLY! (PAIR)
AX TFF-FJ80 $449 pr
TOYOTA F/F CHROMOLY 30 SPL AXLE SHAFTS FITS FZJ80, HDJ80 REAR, FULL FLOAT ONLY! (PAIR)
AX TFF30-L & AX TFF30-R (CTL) $429 pr
TOYOTA F/F 30 SPL CTL AXLE, RH SHORT, Cut to 21.5"-28.9" (FJ40/60/70=24", FJ80-28.9") ELOC OK!
CTL (Cut-to-length). This means the axles come with extra long splines to accommodate numerous applications. -Long splines also allow use of OEM Cable / Electric Locker. Simply chop to desired length. This makes them easy to stock for the average 4x4 shop, as 1 pair of shafts fits many applications.
Individual Axles, Rear Axles, Drive Flanges, Knuckle overhaul kits, wheel bearings and more
Old 08-04-2011, 10:34 AM
Yup. I'm pretty excited about the custom length ones. These could really help out those of us wanting to go to a 9.5 in the rear axle with a centered diff, and 80 series outters.
