Old 08-27-2011, 07:35 PM
1loudLX's Avatar
1loudLX 1loudLX is offline
Default Anyone got a small-diameter pipe bender?
So my RAM mount for the iPad came with an aluminum rod that you bend into shape to fit the vehicle. Works great as a mock up but I think the rod should be made out of steel pipe that you cant bend with your hands. I'll have to measure the diameter unless sandstorm has a caliper handy and can measure his mount. I'd like to get a steel pipe the same diameter and use a pipe bender to make it match the aluminum rod.
2000 Lexus LX470 - Stealth mode: Engaged
2005 Lexus LX470 - ExPo White/'mud Black
I dip my fig newtons.
Old 08-27-2011, 09:28 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
what diameter ?
TLCA # 20314
Step by Step Bed Bob
Old 08-27-2011, 10:02 PM
1loudLX's Avatar
Not home to measure, definitely <1"
Old 08-27-2011, 11:31 PM
TIMZTOY's Avatar
if its a conduit size, im sure several ppl have it, and homedepot sells the tool.. heck they might even rent it. if its brake line size i have one
TLCA # 20314
Old 08-28-2011, 12:33 AM
1loudLX's Avatar
I didn't even think of that. I'll check for the tools when I stop to find the pipe
Old 08-28-2011, 10:07 AM
TIMZTOY's Avatar
TLCA # 20314
Old 08-30-2011, 07:59 PM
I've got a 3/4" round die for my bender.
Old 08-31-2011, 07:34 PM
1loudLX's Avatar
Hold on, I'll be right over!
