Old 08-29-2011, 03:11 PM
CardinalFJ60's Avatar
Default New toy for the Outlaws trip.
so...I got an ARB fridge for the 60. It's way cool. (hee, hee...pun intended).
For those of you who have one, how accurate is the therm on yours. I find that it reads about 5-10 degrees colder on the LED than my little mechcanical one shows when sitting at the bottom.
I cranked it to its coldest (0 degrees F) when it read 0 or -2 on the Panel...the one inside read 10. (still freakin' cold!) as it warms up...like in the fridge temps...it'll read 32 on the LED, but read close to 38- 40 inside.
Does that sound about normal?
Old 08-29-2011, 03:17 PM
I have an older Engel, no fancy read-out or anything of that. I spent $1.98 at Target. The Engel is about 40F at 1.5 on the dial. Gotta keep them full to make the temp even inside, so we put bottles of water inside to take up unused space.
Attachment 24909
Old 08-29-2011, 04:31 PM
Mine consistently reads colder on the panel than it is inside - not sure about the exact variance. I usually run mine at 31 or 33* on the temp gauge, and that keeps the beer mighty cold but nothing ever freezes.
And obviously that rear 1/2 compartment is going to be a bit warmer than the deep, front compartments, so I use that for butter, yogurt, fruit and stuff like that.
Old 08-29-2011, 06:51 PM
treerootCO's Avatar
Event Coordinator
On the 60quart 27°F on the ARB display = 40°F in the fridge
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 08-29-2011, 07:57 PM
Out shopping for toys instead of attending the 40's Run I guess?
Old 08-29-2011, 08:19 PM
Default thanks...so I'm doing well!
thanks for the clarification! I figured as much. right now...reads 29...inside is 36...empty. set at 30
Old 08-30-2011, 09:41 AM
Right on Cardinal, you're going to love it!
