  #91
Old 05-15-2012, 09:54 PM
akingf5371's Avatar
Default Update and help needed
So guys, I haven't posted in a while but things have been going well! I installed FJ40 OEM power steering and took the top off, also got the half doors and tailgate on. I went through the emissions install with the emissions manual and I think it is all hooked up correctly. So, here is my problem. I am testing the AI system and it won't come out of by-pass. It seems to me that the VSV that controls it won't ground and sent it to the cat. I have replaced the computer with two other ones to know avail. I tested the VSV and it switches when supplied power and ground. I have 12V at the plug and the comptuer's ground is grounded. Just doesn't want to switch. Any suggestions? Thanks!!
Adam Farmer
  #92
Old 05-15-2012, 10:14 PM
if you disconnect the cat thermo sensor does it switch out of bypass?
  #93
Old 05-15-2012, 11:13 PM
akingf5371's Avatar
I thought about that, I just have it plugged in and it's sitting in the cab, but it stays in bypass.
Adam Farmer
  #94
Old 05-15-2012, 11:22 PM
un plug it see what happens. it may be shorted?
  #95
Old 05-15-2012, 11:38 PM
akingf5371's Avatar
Hummm, not a bad idea... I want to say I tried that earlier, but it was a number of days ago.
Adam Farmer
  #96
Old 05-16-2012, 06:19 AM
Are you sure the ABV is functional? It may be stuck in bypass mode.
  #97
Old 05-16-2012, 10:34 AM
yeah... does it switch when you manually change the vacuum signal?
  #98
Old 05-16-2012, 10:47 AM
akingf5371's Avatar
Well, when I remove the vacuum line that goes right into the ABV, the one that is connected to the VSV(2) it opens and goes into normal mode.
Adam Farmer
  #99
Old 05-20-2012, 11:52 PM
akingf5371's Avatar
Update! Well with some help I got it to pass emissions! I still can't get it out of bypass but with a little creative tubing work I just bypassed the VSV and injected it right into the exhaust! I'm not sure if it helped that much but I did pass! Got the plates on and everything! It has been a long road and I still need to figure out exactly what is wrong but thanks for the tons of help guys!!
Adam Farmer
  #100
Old 05-21-2012, 12:00 AM
DanS's Avatar
DanS DanS is offline
Awesome!
Street legal and everything! Nicely done.
Dan
