  #111
Old 08-22-2012, 07:04 PM
Originally Posted by akingf5371 View Post
I do have another issue though, whenever I shift into reverse it wants to grind, nothing horrendous but it does sound like I don't have the clutch pressed down. It goes into all the other gears easily enough, just reverse gives me problems. Would this be solved by replacing both the master and slave clutch cylinders?
No. Land Cruiser transmissions are not synchronized for the reverse gear. If the rest of the gears work properly, replacing clutch parts will be a waste of time and money. Just plop it into reverse patiently. You'll get used to it.
  #112
Old 08-23-2012, 10:40 AM
Yeah Like Jeff says, they are grindy in reverse. you gotta wait a bit for the gear cluster to slow down.
I like doing this to check and see if things are working with no drag (pretty much every time I shift into reverse):
  1. be sitting there with the truck in neutral and running.
  2. push in the clutch and move the lever over to get it into reverse.
  3. Don't shift it into reverese fully, but stop just as it feels like the gear teeth are hitting.. not hard, just softly.
  4. Can you hear the gear slowing down or does it keep spinning at the same speed?
  5. If it slows down slowly, you are all good. when it stops plop it into gear. Sometimes they won't line up and you have to move it back and forth a bit.
  6. If it keeps spinning something is dragging a bit. We can diagnose that.
  #113
Old 08-26-2012, 12:28 AM
akingf5371's Avatar
Thanks for the advice Marco! I did you technique and since I've been going slower, I haven't had any problems! When are we swapping our your tub??
Adam Farmer
  #114
Old 08-26-2012, 05:07 PM
Good question! I think he's got some distractions right now....
  #115
Old 08-27-2012, 09:39 AM
I think this winter may be the magic time for the tub...
  #116
Old 08-27-2012, 05:21 PM
BreckBJ44's Avatar
BreckBJ44 BreckBJ44 is offline
Marco, Let me know when you do it... I have a spare set of hands and want to see the process on a newer cruiser...
Kraig Hamady - Encinitas CA
1981 HJZ(BJ)44 RHD - Linked, 1999 100, ready to be built up, 1972 HZJ40 - Work in progress
  #117
Old 08-30-2012, 06:29 AM
akingf5371's Avatar
So, I want to add an aux fuse box under the hood to connect my radio, tach and future upgrades. I was looking at this from painless. Any suggestions? I'm a wiring newbie!
http://www.painlesswiring.com/webcat...rchField=70207
Adam Farmer
  #118
Old 08-30-2012, 09:12 AM
subzali subzali is online now
Looks pretty good, but also check out Blue Sea products:
http://bluesea.com/category/81/21
  #119
Old 08-30-2012, 09:33 PM
Holy mackerel! They sure are proud of that little thing! I built an aux system for my 40 for about $20 worth of parts from Radio Shack. Pretty similar, just roll-your-own.
  #120
Old 08-31-2012, 05:54 PM
PabloCruise's Avatar
If your wheels are at full stop, drop the shifter into 2 or 4 and let those synchros stop the assembly, then hit reverse.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
