  #51
Old 10-03-2011, 06:24 PM
Add a dash a purple and you're close Matt
  #52
Old 10-04-2011, 09:22 PM
kurtnkegger's Avatar
Alright Matt, Tore in to my linkage, and set up...My bracket at the carb was openned up, and getting the linkage to not operate quite right. Going to hit the bracket, and the linkage with the welder, and get things tightenned up. Doing the paperclip thing, I only get about 1/4 inch of travel. How do I manually create vacuum to it?
Every hose I've sucked on gets me nowhere...I feel like Linda Lovelace....
  #53
Old 10-04-2011, 10:28 PM
The vacuum comes from inside the secondary diaphragm housing. If you take the housing off the carb you'll see the hole. It leads to the area right at the venturi, so there is no vacuum unless there is air running past the carb venturi. If the paperclip is traveling at all then you're in good shape, as far as I can tell. Will you have your 40 tomorrow night?
  #54
Old 10-05-2011, 11:32 AM
Planning on bringing it. Since my bracket was openned up from wear, I rounded the hole, and put a brass bushing in there for the pivot point. I filled the worn away groove in the shaft with a little weld...smoothed, and made a couple of aluminum washers for spacers to keep everything in place.
It should only take a few minutes to install...and then I'll have to readjust the throttle linkage...only after lengthening it for enough travel to move the gate did I discover the worn out carb bracket.
  #55
Old 10-05-2011, 11:39 AM
Looks like you have it pretty well in hand Kurt! Yours was definitely not as worn as mine though!
  #56
Old 10-06-2011, 04:29 PM
What is this throttle positioner diaphragm business? I know FI needs to know the TP, but this sounds like something else. Does it have any function at idle, or is it only for throttle positions above idle? I need to look this up when I get home and see if it might have something to do with my 60 stall at idle problem...
  #57
Old 10-06-2011, 04:48 PM
- I'm not sure Radar is old enough to get the reference
  #58
Old 10-06-2011, 04:51 PM
The TP diaphragm holds the throttle plate slightly open when decelerating at high speeds, to prevent an overly rich mixture. I think it also has a function as a choke breaker on some models.
Totally over my head, but I have a feeling it's something I shouldn't look up on my work computer
  #59
Old 10-07-2011, 11:33 AM
I checked my manual and there is no reference to a throttle positioner diaphragm. On my 60 I have 3 vacuum diaphragm actuators on my carb: secondary, AC idle kick up, and choke breaker. The choke breaker just opens the choke a little bit when it is fully closed; once there is vacuum from the engine running it allows a little bit of air to get past the choke butterfly. I don't think it does anything to the throttle, when the choke is closed, the throttle is already partially open from the fast idle.
  #60
Old 10-07-2011, 11:55 AM
Jeff, it looks like your 60 carb is a little different than my '77 FJ40 carb:
FJ60 carb:
'77 FJ40 carb:
On my carb, the choke breaker diaphragm also controls the fast idle screw, or throttle positioner. This doesn't seem to be the case with yours.
By the way, this is different than a throttle positioning sensor. It's not detecting throttle position in any way, but it's rather holding the throttle plates open at certain times.
