  #51
Old 12-18-2011, 07:40 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Originally Posted by rutbeer View Post
Mechanically, nothing scares me, so debating to just jump in and do this unless someone talks me down from the ledge. I do need a better shop space tho. So depending on when you reschedule, I wonder if we can just do two at the same time?
Robbie and I tore down my new-used motor this afternoon. I will post pics later. At 170k the HG was in the initial stages of failure. But the bottom end was in good shape.
Tear down went blindingly fast by Robbie - I was just the helper. If I was doing this all by myself it would have taken me 2-3x longer. Even just the one drive plate bolt where the head stripped was out in short order by Robbie and the grinder - and once the bolt head was off, the rest was finger loose, that could have cost me an hour. I observed several professional grade techniques I had not seen before.
  #52
Old 12-18-2011, 09:29 PM
rockrod rockrod is offline
I am glad the motor seems to be in good shape. I am also glad you are doing the HG. better to do it now while it's out and easy to get to.
curious to see some pics too.
2004 Kona Stinky dee-lux.
  #53
Old 12-18-2011, 11:13 PM
Inukshuk's Avatar
These are all head gasket seeps, Its not supposed to look like that.
  #54
Old 12-18-2011, 11:16 PM
Inukshuk's Avatar
The head itself had never been opened and was fine except for carbon and dino oil gunk.
Where Robbie is pointing is a failure starting at #6, also shown in photo after.
#1 was also starting to go.
But, the cylinder walls were fine.
  #55
Old 12-19-2011, 09:02 AM
OilHammer's Avatar
That's an odd finger to point with....
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #56
Old 12-19-2011, 09:51 AM
Looks like they kept the oil changed in it. Looks nice.
  #57
Old 12-19-2011, 10:07 AM
Caribou Sandstorm's Avatar
It is good to see the big guy on his feet! Even if he is giving us his Iggy Salute...
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
  #58
Old 12-19-2011, 11:40 PM
Inukshuk's Avatar
whoops!
  #59
Old 12-20-2011, 09:06 PM
powderpig's Avatar
Not suppose to be on both feet, I am on one mostly, with a outrigger with the other. It does take it toll on the right leg, can only do it for a couple of hours before I hurt one way or the other. Did not even think which finger I was using in the photo.
  #60
Old 01-21-2012, 12:04 AM
Inukshuk's Avatar
Head is at machine shop.
Parts ordered.
Injectors at WitchHunter
Things are moving........
