  #61
Old 01-24-2012, 03:34 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Default Destination Boulder
I rebuilt the power steering pump too. Missed one o-ring at the very center so it came apart again today - doh. Overall a very easy rebuild though. Just read the FAQ's and go slow. http://forum.ih8mud.com/80-series-te...ent-faq-3.html
Next destination: Boulder.
(in this photo he was not done chaining it down)
  #62
Old 01-27-2012, 12:56 AM
Inukshuk's Avatar
Default Fuel Injector Cleaning
Got the cleaned injectors back today.
These had 170,000 on them.
  #63
Old 01-27-2012, 08:25 AM
Looks like your injectors were in pretty good shape before witchhunter...
  #64
Old 01-27-2012, 10:49 AM
That's what almost every set I've sent to them went to and came back looking like. Kinda funny. Worth it for the piece of mind though.
  #65
Old 01-27-2012, 11:48 AM
OilHammer's Avatar
What are they actually doing to them? Just pressure/solvent cleaning, or do they actually take them apart and replace components? With the diesels, you can replace the injector tips fairly economically, but that shouldn't happen before gobs of miles. Seems like the gasoline injectors would actually run even cleaner than the diesel since you are essentially pumping filtered solvent through them all the time.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #66
Old 01-27-2012, 12:07 PM
They test as recieved then the ultrasonicly solvent clean them then they retest. Same as the other mail in injector guys. I swear that report card looks the same as several I have got back. Must be a form letter! Last set I got back had one that leaked down overnight. Seems the leakdown test should have spotted that. Not dissing Witchhunter at all....great company, fast and rather inexpensive.
  #67
Old 01-27-2012, 05:58 PM
Inukshuk's Avatar
They clean as UB said and also replace the o-ring, seal, tip cover and filter screen.
More progress. This is my motor. I had to be in Boulder this AM and stopped by to see Robbie for a bit.
  #68
Old 01-27-2012, 06:06 PM
schwing!!!!
  #69
Old 01-28-2012, 12:00 AM
Yeah man, looking good.. the end is near! it would be so easy to bolt on that 3-groove pulley for the OBA right now..
  #70
Old 01-28-2012, 07:27 AM
Inukshuk's Avatar
