  #81
Old 02-02-2012, 08:33 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
That's sweet Daniel!
Thanks, and great Land use report and guest last night.
That is looking real nice Daniel. Should be good to go for a long time now.
Thanks.
I'm going to give her a good cleaning, check the fluids obsessively for a few weeks and I have already started a write up of some thoughts on the job and process overall. Number one being all the people involved.
CDan - Dan Bussey - American Toyota
Corey - aka Rockrod and the donor engine.
Two friends who lent me cars for **five** months.
Ace Towing - (Larry, 720-338-5230) and Kelley Eyen State Farm Insurance that paid for it.
Now off to work cause I'm still paying for it....
  #82
Old 04-11-2012, 11:27 PM
thelal thelal is offline
Send a message via AIM to thelal Send a message via MSN to thelal Send a message via Yahoo to thelal Send a message via Skype™ to thelal
Originally Posted by thelal View Post
Dan
I'm in a similar boat. I've a 97 I picked up at 200K and now 240K. ...
Losing some power under load and diagnosed with appears to be' leaky values' on #5 and #6
So I could continue as-is and take it 'easy' but not sure how long this will take me. I could get HG redone, values etc.. and should last 100-150K?
However don't have the molla to do a full rebuild now so considering just a HG/value 'fix' for 100-150K. Is that worth it?
Any other options
So I ended up taking that engine out and getting another one switched in (30K on a Robbie special rebuild with some xtra oomph 'bits'). Took 2-3 days but it was night-n-day on first drive out of the shop - lots of pep and need to be careful with that R foot.
Very pleased with results.
Now need to refix my fan clutch (just drained/refilled with 10K oil but no difference) as still heating up after new radiator.
  #83
Old 04-12-2012, 12:13 AM
Inukshuk's Avatar
But you are running hot?
I'm doing great, about 3,000 miles, one oil change, zero leaks or consumption, and one speeding ticket. very smooth all the way to redline. Have not yet passed emissions but the cats and O2 sensors came off the donor rig and the age was unknown - though they had 170,000 miles. New O2 sensors should be here tomorrow or Friday.
  #84
Old 04-14-2012, 03:33 AM
Inukshuk's Avatar
my old downpipes are back on with new O2 sensors. The O2 sensors that were there from the donor rig looked fairly new. The nuts were not all rusted up.
Key to this job were that the hardware was all relatively new and 24" of socket extensions and a wobbly one at the end (they rock), also ratcheting box end wrenches. Shout out to Edgewater Ace Hardware that sold me two loose ones they had in back for $10.
Last week I tested catalytic converter temperatures and got:
Driver - 430 in, 530 out
Passenger - 410 in, 510 out
Monday we try emissions again and if that fails, new cats.
  #85
Old 04-16-2012, 09:46 PM
Inukshuk's Avatar
We Passed Emissions!!
__________Test 1____Test 2_______Test 3
HC_______0.346______0.1889______0.3118
CO_______3.984______4.000_______9.649
CO2______867.6______706.0_______766.5
Nox______9.354______9.256_______3.024
Test 1: no special prep, short wait, idled at 2,000RPM
Test 2: tank premium, two cans red HEET, tires at 50PSI, well warmed up, short wait, idled at 2,000RPM
Test 3: NEW O2 Sensors, tank premium, tires at 50PSI, no HEET, 15 minute wait, idled at 3,000RPM
Tires were 285/75R16 Nitto Terra Graplers.
So, HEET brings down HC and CO2, seems to not affect CO or Nox, and bad O2 sensors affect NOx. As noted before, catalytic converters measured a 100 degree temperature rise so between that and this test they seem to be working fine.
Since I could not find it posted anywhere (here or MUD) ill searchably write bad O2 sensors cause high NOx readings. Lower NOx by getting new O2 sensors. I used Toyota OEM oxygen sensors.
Than you again Robbie for suggesting I test after replacing the O2 sensors and before changing catalytic converters. Heated 4-wire O2 Sensors as we have in our cruisers should have a 60,000 - 100,000 mile life.
  #86
Old 04-16-2012, 10:46 PM
Default running hot
.. one speeding ticket..
Glad alls running well and you got your emissions.
Ha! on the speeding ticket - hard to keep the 'new' truck on even keel
On 3rd drain/refill on the fan clutch - didn't have enough in last 2 times (as each time if takes some more). Either the 10K fluid is wrong type or fan clutch is hosed as not making any difference once I start climbing hills..
  #87
Old 04-18-2012, 08:59 PM
rockrod rockrod is offline
cool stuff.
I wonder if the previous owners had the cats replaced at some point.
I will post my numbers with the V8 soon. I am not to far from having it ready for the inspector to 'stamp it' with their approval.
2004 Kona Stinky dee-lux.
  #88
Old 04-18-2012, 09:57 PM
Inukshuk's Avatar
Originally Posted by rockrod View Post
cool stuff. I wonder if the previous owners had the cats replaced at some point.
Hard to say, we both know how bad the bolts were.
What emissions do you have to qualify for?
  #89
Old 04-19-2012, 06:28 AM
powderpig's Avatar
My guess is that they were the original cats.
  #90
Old 05-04-2012, 02:40 PM
Default Fan clutch fixed
I think I drained/refilled the fan clutch about 4+ times, with 10K and then 15K CST in the end. What worked in the end was putting in a sealant gasket (on top of existing O-ring) as it 'appeared' to be leaking (as in each time I came back to check it needed more fluid, but positive that each time I had filled to the brim (including letting it sit overnight for the fluid to settle))
When it was 'failing' the (when engine cold and spinning by hand) resistance would change. 1st spin would be stiff, next a little less, next one easier etc.. or I would have intermittent "stiffness" as I spun.
Now resistance is the same and temps no more than 180-185f on step climb (3-4K) up Rt 7 towards Allenspark. Prev. was easy to get it up to 220f (all temps measured via UltraScan guage)
