Old 06-26-2006, 10:32 PM
treerootCO's Avatar
Event Coordinator
IMO the purpose of a thermostat is to keep coolant in the radiator long enough for it to dissipate the heat. I run a hotter thermostat and it keeps my engine cooler. If the upper o-ring was missing it could potentially rattle around and let coolant past before it has a chance to cool. It would be a restriction either way and probably wouldn't matter in the grand scheme of things.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 06-26-2006, 10:51 PM
Originally Posted by Uncle Ben
Who said anything about the lower portion of the block?
I did, based on visual observations of the last couple of blocks I was inside, and was adding and amplifying on your comment about the flow being less in the rear of the block's water jacket.
Old 06-26-2006, 11:00 PM
74fj40's Avatar
74fj40 74fj40 is online now
Originally Posted by Rzeppa
For this reason, a muriatic acid soak/flush might be feasable, inexpensive and potentially efficacious.
do you have any mroe info on this? can it ben while the engine is in the car? or does the engine have to be completely torn apart?
thanks in advanced
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
  #24
Old 06-26-2006, 11:16 PM
drain rad fluid. fill with flush...run engine to operating temps, drain, flush a couple times and refill with antifreeze/water mix.
  #25
Old 06-26-2006, 11:43 PM
What Ige said. Basically, you don't want the muriatic acid anywhere near anything aluminum, such as the t-stat housing, it'll eat it up. But cast iron like the block, head or F water pump housing won't care.
  #26
Old 06-26-2006, 11:49 PM
treerootCO's Avatar
Event Coordinator
Ige forgot a major part! First you need to buy an all original '64 40 that hasn't run in 25 years but fired right up and even had brakes. Then after the whole flushing process, you leave nice clean water in the block the ONE DAY IT GOT COLD ENOUGH TO FREEZE SOLID!!
At least that is my experience when I cracked the block in two.
www.root45.com
TLCA #14133
  #27
Old 06-27-2006, 12:00 AM
remove the flux capacitor. They don't work well at altitude
has to be something treeroot listed. He covered most everything Let me know if you need a hand otherwise i'll be sealing up a tranny and xfer. I might need a hand if you guys have a 1/2 hour or so getting it back in.
WØREK
  #28
Old 06-27-2006, 08:03 AM
74fj40's Avatar
can't remove the flux capacitor - only way we can afford to run it... We'll be around - just let us know when..
1972 Toyota FJ40
[/font]
  #29
Old 06-27-2006, 08:04 AM
74fj40's Avatar
hey wes, thanks for the offer. and we'll most likely have to take you up on that.
but if you still want help on putting the tranny and xfer back in, just let me know
1972 Toyota FJ40
[/font]
  #30
Old 07-04-2006, 12:50 PM
74fj40's Avatar
OK- checked the compression numbers today.
1-120
2-118
3-119
4-120
5-120
6-120
1972 Toyota FJ40
[/font]
