  #31
Old 08-15-2012, 12:53 PM
I run a lock and roll on my trailer. It is a breeze to hook up. No harder than a ball if you ask me. And as long as your tongue weight is correct you should be able to man handle the trailer onto the hitch without issue. I find the articulation actually more forgiving than getting the ball dead on.
FWIW, the quietness of this hitch is worth it alone. I have a couple 1000 miles on mine and it is super tight and quiet as the day I brought it home. I use a little high pressure grease smeared onto the bearing surfaces before heading out and it tows like a quiet dream. If you have ever driven a pintel hook, then a ball hitch, and realized the difference in slop and noise... there is the same reduction in slop and noise AGAIN from the ball hitch to the lock-n-roll.
Tim, feel free to come check mine out in person, or give it a run on your little trailer sometime, the only issue is you will need to receivers to run this setup. If your trailer sees dirt at all this thing is worth it.
  #32
Old 08-15-2012, 03:00 PM
Originally Posted by 74fj40 View Post
im gay
This made me laugh out loud. Not sure if it was your official coming out, or maybe your girl friend was on your computer and did a funny... or perhaps you're just really witty. in any case
Ok onto the other comments, thanks guys. Jeff the dude at LocknRoll said he just improved his design, the part numbers he gave me aren't even on his web site. I'm thinking he must have addressed whatever was happening... also what I'm looking at doesn't have a receiver on the trailer side, it's more of a weld-on deal.
I like of like the added security benefit... you'd have to get creative to hork my trailer without the mating part, ya know?
Drew that's cool you have one, given that you're a mile away with some experience pretty much clinches it.. you'll have to hook this bad boy up to the Sequoia some time when I get it all built up.
  #33
Old 04-17-2013, 01:26 PM
Bringing this back up to the top.
I ordered a Max Coupler yesterday and plan to weld in the receiver to the Starcraft 10R/T next week in prep for CM13.
I looked at the Lock and Roll as well. Dave Druck prefers that on his teardrop. It looked like there were a few failures with that unit when using the bolt-on version to a standard drop receiver. Dave uses the welded receiver/coupler. He had too many failures with the Max Coupler and switched.
I believe either coupler choice would be a good one at this point.
Anyway as I don't know how much drop I'll need at this point so I chose the Max Coupler. Purchased from So-Cal Teardrops for $235 to my door. Better pricing than AT. Its a new and improved model what ever that means. Will post pics when done.
  #34
Old 04-17-2013, 02:08 PM
74fj40's Avatar
74fj40 74fj40 is offline
Lol just saw this. Must have been my roomate...
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
  #35
Old 04-17-2013, 03:00 PM
Lock and roll definitely has way more options to offer the user the best possible solution.
  #36
Old 04-23-2013, 11:29 PM
So I welded the receiver tube in tonight. Funny as I have the exact same pop-up as originally posted. I added a little more length to prevent my spare tire from contacting the propane tanks and tongue jack. But basically the same mod. I boxed in the bottom of the tongue and placed a support brace below the receiver to add additional strength.
Size:  90.2 KBName:  ImageUploadedByTapatalk1366777558.818616.jpg
  #37
Old 04-24-2013, 10:49 AM
And it was the exact same pop-up that inspired me to buy the pop-up that you bought from me...
KDěRCH
  #38
Old 04-24-2013, 05:51 PM
Tested out the max coupler today. My only complaint is hooking it up solo. I'm going to guess that Lock and Roll is easier solo. My camper is too heavy to lift the tongue and move it by hand. So lining up the pin is a PITA. But once connected everything works great. Name:  ImageUploadedByTapatalk1366843801.036471.jpg
Size:  75.2 KBName:  ImageUploadedByTapatalk1366843816.651047.jpg
Size:  65.8 KBName:  ImageUploadedByTapatalk1366843834.867648.jpg
