Old 12-13-2011, 10:57 PM
rockrod rockrod is offline
Default 1994 FZJ80 5.3l and 4L60e swap
So add me to the list of the vortec swappers.I have owned my 80 for a little over a year now and while it's been a great truck, the lack of power is getting old.
I was given the green light by the CFO to move forward with the swap.I sourced a low mileage 2006 Vortec L33 5.3l engine and 2003 4L60e 4 spd automatic transmission.
The L33 is an all aluminum V8 and is based on the LS6. It runs Z06 heads, 9.9 compression ratio, and the cam has a bit more lift (same duration) over an iron block 5.3l motor. It's rated at 310 hp and 335 ft/lbs of torque. It will make a good bit more than that because I had the PCM tuned for performance. It will be closer to 350hp and 350 ft/lbs of torque.The last few weeks have been mostly a mission of gathering the parts. I relied heavily on the previous LSx swap threads to come up with the list and I have manage to gather a lot of what's needed. I am still waiting on the t-case adapter from Advanced. I am keeping the stock full time t-case.A few more pics of the motor with the f-body pan swap done and LS3 exhaust manifolds installed:
I am doing my own wiring harness adaptation and have built my own fuse block to run the motor:
I am using an FJ80 shifter to keep the stock look:
I am using a dual fan 2 speed unit from a mid '90s lincoln continental. It's essentially two taurus fans that run together. The PCM will control the fans.
I started the dissasembly of the 80 last night. This project will move pretty slow since I work full time and my wife and I are raising 2 year old triplets. I don't have a lot of free time so work will mostly happen at night.
Stay tuned!
2004 Kona Stinky dee-lux.
Old 12-13-2011, 10:58 PM
pile of parts is getting bigger:
front end getting stripped down:
2WD 4L60e I will be using:
Notice the difference in the MLPS on the side of the transmission. 2004 was the transition year and GM switched from the 2 plug style to the single plug style for the later years. My engine is a 2006 and the trans is a 2003, so a swap to the later style to update this trans is in order. It's an R&R deal:
more tomorrow night.
Old 12-13-2011, 11:13 PM
74fj40's Avatar
74fj40 74fj40 is online now
Keep up the good work! Will definitely be following!
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 12-13-2011, 11:57 PM
Sounds like fun! Let me know if you have any questions... I have about 90,000 miles on my 5.3 vortec swap in my 60 and I have learned a lot of things along the way..
Old 12-14-2011, 12:09 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
PM Sent on the old motor. I'll be watching too.
Old 12-14-2011, 12:35 AM
Btw, I'd recommend going with a mechanical fan if you can.. I just looked through this again and thought that. My electric defile cooled well but were never really that reliable.
Old 12-14-2011, 07:16 AM
The fan I am using is an OEM ford fan. here's a shot of it sitting on the stock '94 radiator.
If it doesn't work, then I will switch to the mechanical fan.
Old 12-14-2011, 12:19 PM
Nice work -
Question - what do you planning on doing with the Power Steering?! Are you going to adapt the Toyota P/S pump to the new engine, or are you going to use the GM P/S pump and just swap the lines to and from it?! If so, who's going to make custom hoses for ya?
Good luck with the swap - looking good.
James
James DePaul
Old 12-14-2011, 02:58 PM
Originally Posted by Overlander View Post
Nice work -
James
good question. The solution is very easy. The toyoto steering box uses a 5/8s ORB fitting. Russell Performance makes the powerflex line of teflon braid hoses designed just for hydraulics and high pressure applications. They sell adapters that fit the gm/saginaw pump and the steering box that allow -06 JIC style fitting equipped hose to join the two up. I used a very similar setup on my old jeep CJ-7 crawler and it's full hydro steering. The hose is built using regular hand tools.
here's more info on the hose construction:
http://www.russellperformance.com/mc...steering.shtml
and these are the fittings for the pump and steering box
http://www.russellperformance.com/mc...t/fit_ps.shtml
Old 12-14-2011, 03:01 PM
Also forgot to mention - integrating the toyota AC system. This will be a bit more challenging but I think I found a solution for this as well. I have to have a custom discharge and suction hose made up so that they will fit the toyota condensor and evap ports on one side and the denso compressor on the engine side.
