  #31
Old 12-19-2011, 09:43 AM
So are you going to throw the temp sensor in the right head on this one?
  #32
Old 12-19-2011, 11:35 AM
rockrod rockrod is offline
I will probably drill and tap the water pump housing so that I get a good representation of the combined temp output.
2004 Kona Stinky dee-lux.
  #33
Old 12-27-2011, 08:28 PM
Sorry - no updates as of yet. I am still waiting for the adapter. As soon as it arrives, there will be lots of action. stay tuned...
  #34
Old 12-28-2011, 10:28 AM
I'm thinking having a stock of 80 series ring and pinion sets could set a guy up with a side job once these conversions get popular...
Kewl...
KDRCH
  #35
Old 12-28-2011, 10:50 AM
Kewl...
It's just the mini truck crap in the fronts you need to keep in stock! That and steering gears/sector shafts and you could be a rich man!
  #36
Old 12-29-2011, 10:00 PM
update:
Started doing two things. I pulled the fuel pump assembly in preparation for swapping the pump with a high pressure/volume unit to keep up with the motor:
new pump and install kit
Pulled assembly from tank after removing rear seats and carpet
pump assembly on the work bench. I also have to install a fuel tank pressure sensor for emissions
I also started working on stripping the 1FZ engine harness down. I spent the last few days translating the EWD over to a simple spread sheet with the connector diagram, wire colors, and circuit:
one of my spread sheets
  #37
Old 12-29-2011, 10:30 PM
cool, looks like good progress. I am glad you are doing the wiring yourself.
  #38
Old 12-31-2011, 05:13 PM
A little more progress on the 1FZ harness prep...
This is the discard:
These two harness lead to the IH1 and IH2 connectors that make the connection to the body harness behind the glove box:
There will be 5 connections made between the IH1 and IH2 harnesses and the Vortec PCM harness. I will show these later.
  #39
Old 01-07-2012, 08:57 AM
well - what do you know....
look what showed up last night - two months after ordering:
I also ordered a Delta Current Control variable speed control for the fans. It took about 3 weeks to get:
Now I can get down to business!
  #40
Old 01-11-2012, 12:19 PM
Wow, I am super stoked about seeing this one come together. I appreciate you taking the time to post all the pics, it gives a real sense of the work involved.
The wiring spooks me about this swap... looks like you've got it covered!
